Ir para o conteúdo principal
Dell Precision M4400 Memory Module Replacement
O que você precisa
  1. Dell Precision M4400 Memory Module Replacement, Battery: passo 1, imagem 1 %32
    • Slide the battery release latches to the open position. (The latches lock into place).
    • Grip the battery and slide it out of the battery bay.
    Pergunte ao FixBot
    Comentar
  2. Dell Precision M4400 Memory Module Replacement, Base Cover: passo 2, imagem 1 %32
    • Loosen the M2.5 x 5-mm captive screw.
    • Using the rubber feet for leverage, slide the bottom of the base assembly toward the front of the computer 1/8th inch, then lift to remove it.
    Pergunte ao FixBot
    Comentar
  3. Dell Precision M4400 Memory Module Replacement, Memory Module: passo 3, imagem 1 %32
    • To remove the DIMM module, spread away the retaining clips from the side edges of the memory module and lift the free edge of the module so that it sits at about a 30-degree angle to the system board.
    • Grasp the module at the side edges and pull it straight away from the connector. Place the module into anti-static packaging such as an anti- static bag.
    Pergunte ao FixBot
    Comentar
Conclusão
Johnathan Hammond
Membro desde: 02/28/18
46.149 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
45 Membros
Autoria de 2.003 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 31
Ao todo: 694
