Ir para o conteúdo principal
Dell Precision 7560 Keyboard Replacement
O que você precisa
  1. Dell Precision 7560 Keyboard Replacement, Battery: passo 1, imagem 1 %32 Dell Precision 7560 Keyboard Replacement, Battery: passo 1, imagem 2 %32 Dell Precision 7560 Keyboard Replacement, Battery: passo 1, imagem 3 %32
    • The screws holding the back cover in place can not be removed.
    • Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
    • Remove the back cover by lifting at the corners.
  2. Dell Precision 7560 Keyboard Replacement: passo 2, imagem 1 %32 Dell Precision 7560 Keyboard Replacement: passo 2, imagem 2 %32 Dell Precision 7560 Keyboard Replacement: passo 2, imagem 3 %32
    • Unscrew and remove the five 2 mm screws that secure the battery.
    • Locate the battery connector.
  3. Dell Precision 7560 Keyboard Replacement: passo 3, imagem 1 %32 Dell Precision 7560 Keyboard Replacement: passo 3, imagem 2 %32 Dell Precision 7560 Keyboard Replacement: passo 3, imagem 3 %32
    • Pull the connector towards you to disconnect it.
    • Use your fingers or a plastic opening tool to pry the battery up and remove it from the laptop.
  4. Dell Precision 7560 Keyboard Replacement, Keyboard: passo 4, imagem 1 %32 Dell Precision 7560 Keyboard Replacement, Keyboard: passo 4, imagem 2 %32 Dell Precision 7560 Keyboard Replacement, Keyboard: passo 4, imagem 3 %32
    • With the back cover and battery removed, locate the ribbon cables connected to the keyboard.
    • Pulling from the tab, carefully remove the connector.
  5. Dell Precision 7560 Keyboard Replacement: passo 5, imagem 1 %32 Dell Precision 7560 Keyboard Replacement: passo 5, imagem 2 %32 Dell Precision 7560 Keyboard Replacement: passo 5, imagem 3 %32
    • Turn the device over and open the screen to expose the keyboard.
    • Using an opener tool, pry along the edges of the keyboard to remove the keyboard's plate cover.
  6. Dell Precision 7560 Keyboard Replacement: passo 6, imagem 1 %32 Dell Precision 7560 Keyboard Replacement: passo 6, imagem 2 %32 Dell Precision 7560 Keyboard Replacement: passo 6, imagem 3 %32
    • With the plate cover removed, use the screwdriver to remove each of the six 2 mm screws.
    • Carefully remove the keyboard from the device.
Conclusão
Jack Allred
Membro desde: 02/09/23
345 Reputação
Autoria de 2 guias
Equipe
Um comentário
Guide is close, but not completely correct. Just need a little more attention to detail.
Barry Todd - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 57
Ao todo: 1,063
