Ir para o conteúdo principal
Dell Precision 7510 Memory Module Replacement
O que você precisa
  1. Dell Precision 7510 Memory Module Replacement, Removing the Battery Cover: passo 1, imagem 1 %32
    • Slide the release latch to unlock the battery cover.
    • Slide and lift the battery cover to remove it from the computer.
    Pergunte ao FixBot
    Comentar
  2. Dell Precision 7510 Memory Module Replacement, Removing the Battery Cover: passo 2, imagem 1 %32
    Pergunte ao FixBot
    Comentar
  3. Dell Precision 7510 Memory Module Replacement, Removing the Hard Drive: passo 3, imagem 1 %32
    • Remove the screws that secure the hard drive to the computer.
    • Lift the hard-drive latch to the unlock position.
    • Slide and lift the hard drive from the computer.
    Pergunte ao FixBot
    Comentar
  4. Dell Precision 7510 Memory Module Replacement, Remove the Screws: passo 4, imagem 1 %32
    • Remove the screws that secure the hard drive. Lift the hard drive away from the bracket.
    Pergunte ao FixBot
    Comentar
  5. Dell Precision 7510 Memory Module Replacement, Removing the Keyboard Cables: passo 5, imagem 1 %32
    • Peel the tape to access the cable.
    • Lift the tab and disconnect the keyboard cables from the system board.
    Pergunte ao FixBot
    Comentar
  6. Dell Precision 7510 Memory Module Replacement, Removing the Keyboard: passo 6, imagem 1 %32
    • Pry the keyboard trim starting from bottom and work along the top edge and remove it away from the computer.
    • Remove the screws that secure the keyboard to the computer.
    • Lift the front side and slide the keyboard to remove it away from the computer.
    Pergunte ao FixBot
    Comentar
  7. Dell Precision 7510 Memory Module Replacement, Removing the Memory Module: passo 7, imagem 1 %32
    • Remove the screw that secures the memory shield to the computer.
    • Lift and remove the memory shield from the computer.
    • Pry the retention clips away from the memory module until it pops up.
    • Lift the memory module and remove it from the computer.
    Pergunte ao FixBot
    Comentar
  8. Dell Precision 7510 Memory Module Replacement, Removing the Memory Module: passo 8, imagem 1 %32
    • Pry the retention clips away from the primary memory until it pops up.
    • Lift the primary memory and remove it from the computer.
    Pergunte ao FixBot
    Comentar
Linha de Chegada
Johnathan Hammond
Membro desde: 02/28/18
46.149 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
45 Membros
Autoria de 2.003 guias
1Comentário do guia
Thanks Johnathan. Step 4 is unnecessary.
Joseph R. Scandora - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 17
Últimos 30 dias: 59
Ao todo: 11,956
