Ir para o conteúdo principal
Dell Precision 5520 Memory Module Replacement
O que você precisa
  1. Dell Precision 5520 Memory Module Replacement, Base Cover: passo 1, imagem 1 %32 Dell Precision 5520 Memory Module Replacement, Base Cover: passo 1, imagem 2 %32
    • Be sure to power off and unplug your device before you begin your repair.
    • Turn the system badge flap over (1) and then remove the ten M2x3 screws that secure the base cover to the computer (2).
    • Pry the edges of the base cover and lift it to remove it from the computer.
    • NOTE: Use a Torx #5 screwdriver for the base screws and a Phillips screwdriver for the two M2x8 screws inside the badge flap.
    Pergunte ao FixBot
    Comentar
  2. Dell Precision 5520 Memory Module Replacement, Battery: passo 2, imagem 1 %32
    • Disconnect the battery cable from the system board [1].
    • Remove the seven M2x4 screws that secure the battery to the computer [2].
    • Lift the battery off the computer [3].
    • Do not apply pressure to the surface of the battery
    • Do not bend
    • Do not use tools of any kind to pry on or against the battery
    • If a battery cannot be removed within the constraints above, please contact Dell technical support
    Pergunte ao FixBot
    Comentar
  3. Dell Precision 5520 Memory Module Replacement, Memory Module: passo 3, imagem 1 %32
    • Pry the securing clips away from the memory module until it pops-up [1]. Then, remove the memory module from its connector on the system board [2].
    Pergunte ao FixBot
    Comentar
Conclusão
Johnathan Hammond
Membro desde: 02/28/18
46.158 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
45 Membros
Autoria de 2.003 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 25
Ao todo: 1,816
