Ir para o conteúdo principal
Dell Precision 3510 Display Assembly Replacement
O que você precisa
  1. Dell Precision 3510 Display Assembly Replacement, Battery: passo 1, imagem 1 %32 Dell Precision 3510 Display Assembly Replacement, Battery: passo 1, imagem 2 %32
    • Flip the computer over so that you are looking at the bottom.
    • Use a Phillips #000 screwdriver to remove the eight 6.5 mm screws from the base cover.
    Pergunte ao FixBot
    Comentar
  2. Dell Precision 3510 Display Assembly Replacement: passo 2, imagem 1 %32
    • Use the opening tool to carefully pry the base cover from the computer.
    • Remove the base cover from the laptop.
    Pergunte ao FixBot
    Comentar
  3. Dell Precision 3510 Display Assembly Replacement: passo 3, imagem 1 %32 Dell Precision 3510 Display Assembly Replacement: passo 3, imagem 2 %32
    • Using a Phillips #000 screwdriver, remove the two 5.5 mm screws from the battery.
    Pergunte ao FixBot
    Comentar
  4. Dell Precision 3510 Display Assembly Replacement: passo 4, imagem 1 %32 Dell Precision 3510 Display Assembly Replacement: passo 4, imagem 2 %32
    • Gently unplug the cable connected to the top of the battery.
    • Remove the battery from the laptop.
    Pergunte ao FixBot
    Comentar
  5. Dell Precision 3510 Display Assembly Replacement, Power Connector Port: passo 5, imagem 1 %32 Dell Precision 3510 Display Assembly Replacement, Power Connector Port: passo 5, imagem 2 %32
    • Use a Phillips #000 screwdriver to remove the single 3 mm screw from the metal bracket that secures the power port.
    Pergunte ao FixBot
    Comentar
  6. Dell Precision 3510 Display Assembly Replacement: passo 6, imagem 1 %32 Dell Precision 3510 Display Assembly Replacement: passo 6, imagem 2 %32
    • Lift the metal bracket and gently remove the power connector port.
    • Unplug the power connector port cable from the system board.
    Pergunte ao FixBot
    Comentar
  7. Dell Precision 3510 Display Assembly Replacement, WLAN Card: passo 7, imagem 1 %32
    • Use a Phillips #000 screwdriver to remove the single 3 mm screw securing the metal bracket to the WLAN card.
    • Remove the metal bracket from the system board.
    Pergunte ao FixBot
    Comentar
  8. Dell Precision 3510 Display Assembly Replacement: passo 8, imagem 1 %32
    • Carefully detach the two cables that are connected to the WLAN card.
    Pergunte ao FixBot
    Comentar
  9. Dell Precision 3510 Display Assembly Replacement: passo 9, imagem 1 %32
    • Remove the WLAN card from the system board.
    Pergunte ao FixBot
    Comentar
  10. Dell Precision 3510 Display Assembly Replacement, Display Assembly: passo 10, imagem 1 %32
    • Use a Phillips #000 screwdriver to remove the 6.5 mm screws from each display hinge bracket.
    • Remove the two hinge brackets from the computer.
    Pergunte ao FixBot
    Comentar
  11. Dell Precision 3510 Display Assembly Replacement: passo 11, imagem 1 %32
    • Carefully unroute the WLAN cables from the system board.
    Pergunte ao FixBot
    Comentar
  12. Dell Precision 3510 Display Assembly Replacement: passo 12, imagem 1 %32 Dell Precision 3510 Display Assembly Replacement: passo 12, imagem 2 %32 Dell Precision 3510 Display Assembly Replacement: passo 12, imagem 3 %32
    • Use a Phillips #000 screwdriver to remove the 3 mm screw from the metal bracket that secures the eDP cable.
    • Gently disconnect the eDP cable from the system board.
    • Unroute the display cable from the system board.
    Pergunte ao FixBot
    Comentar
  13. Dell Precision 3510 Display Assembly Replacement: passo 13, imagem 1 %32 Dell Precision 3510 Display Assembly Replacement: passo 13, imagem 2 %32
    • Use a Phillips #000 screwdriver to remove the four 4.5 mm screws that secure the display assembly to the system board.
    • Flip the computer face up.
    • Carefully remove the WLAN cables and the display cable from the laptop.
    Pergunte ao FixBot
    Comentar
  14. Dell Precision 3510 Display Assembly Replacement: passo 14, imagem 1 %32
    • Detach the display assembly from the system board.
    Pergunte ao FixBot
    Comentar
Conclusão
Makenna Patrick
Membro desde: 09/24/25
643 Reputação
Autoria de 5 guias
Equipe
Texas Tech, Team 46-3, Johansen Fall 2025 Membro de Texas Tech, Team 46-3, Johansen Fall 2025
TTU-JOHANSEN-F25S46G3
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 31
Ao todo: 168
