Ir para o conteúdo principal
Dell Photo Printer 720 Encoder Strip Replacement
O que você precisa
    1. Dell Photo Printer 720 Encoder Strip Replacement, Encoder Strip: passo 1, imagem 1 %32 Dell Photo Printer 720 Encoder Strip Replacement, Encoder Strip: passo 1, imagem 2 %32 Dell Photo Printer 720 Encoder Strip Replacement, Encoder Strip: passo 1, imagem 3 %32
      • Use a Phillips head #2 screwdriver to remove the 4 screws located on the bottom of the Dell Photo Printer 720.
      Pergunte ao FixBot
      Comentar
    2. Dell Photo Printer 720 Encoder Strip Replacement: passo 2, imagem 1 %32 Dell Photo Printer 720 Encoder Strip Replacement: passo 2, imagem 2 %32 Dell Photo Printer 720 Encoder Strip Replacement: passo 2, imagem 3 %32
      • Use a spudger to wedge between the cover and base of the printer (where the light grey and black portions meet).
      • Pry apart the light grey cover from the black base.
      • Gently flip the printer upright to its standard position and carefully lift off the cover.
      Pergunte ao FixBot
      Comentar
    3. Dell Photo Printer 720 Encoder Strip Replacement: passo 3, imagem 1 %32 Dell Photo Printer 720 Encoder Strip Replacement: passo 3, imagem 2 %32
      • Slide the ink cartridge from the right side to the middle left so it is out of the way.
      Pergunte ao FixBot
      Comentar
    4. Dell Photo Printer 720 Encoder Strip Replacement: passo 4, imagem 1 %32 Dell Photo Printer 720 Encoder Strip Replacement: passo 4, imagem 2 %32 Dell Photo Printer 720 Encoder Strip Replacement: passo 4, imagem 3 %32
      • Grab ahold of the encoder strip on the right side. Gently tug the strip outward and swing the end piece towards you to unhook the encoder from the prong.
      • Carefully unhook the opposite end of the encoder strip to full disconnect the part.
      • To replace new encoder strip, reattach each end to the hooks by reversing previous steps.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Megan Lawrence
Membro desde: 01/14/15
534 Reputação
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 37
Ao todo: 1,060
