Ir para o conteúdo principal
Dell Optiplex SX280 RAM Replacement
  1. Dell Optiplex SX280 RAM Replacement, Panel Cover: passo 1, imagem 1 %32
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
    Pergunte ao FixBot
    Comentar
  2. Dell Optiplex SX280 RAM Replacement: passo 2, imagem 1 %32 Dell Optiplex SX280 RAM Replacement: passo 2, imagem 2 %32
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
    Pergunte ao FixBot
    Comentar
  3. Dell Optiplex SX280 RAM Replacement: passo 3, imagem 1 %32 Dell Optiplex SX280 RAM Replacement: passo 3, imagem 2 %32
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
    Pergunte ao FixBot
    Comentar
  4. Dell Optiplex SX280 RAM Replacement, RAM: passo 4, imagem 1 %32
    • The RAM are the two green cards in the corner of the computer.
    • At each end of the card, there are two white clips securing the RAM to the Motherboard.
    Pergunte ao FixBot
    Comentar
  5. Dell Optiplex SX280 RAM Replacement: passo 5, imagem 1 %32 Dell Optiplex SX280 RAM Replacement: passo 5, imagem 2 %32
    • Push down both white clips with your thumbs until you hear a click.
    • The RAM cards can now be removed.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions (steps 1-3) in reverse order.
8 outras pessoas executaram este guia.
Wyatt
Membro desde: 10/06/10
784 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 22-4, Maness Fall 2010 Membro de Cal Poly, Team 22-4, Maness Fall 2010
CPSU-MANESS-F10S22G4
4 Membros
Autoria de 26 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 34
Ao todo: 5,853
