Ir para o conteúdo principal
Dell Optiplex GX620 Floppy Drive Replacement
O que você precisa
    1. Dell Optiplex GX620 Floppy Drive Replacement, How to unplug and discharge before repair: passo 1, imagem 1 %32 Dell Optiplex GX620 Floppy Drive Replacement, How to unplug and discharge before repair: passo 1, imagem 2 %32
      • Power down your PC and remove the power cord from the back.
      Pergunte ao FixBot
      Comentar
    2. Dell Optiplex GX620 Floppy Drive Replacement: passo 2, imagem 1 %32 Dell Optiplex GX620 Floppy Drive Replacement: passo 2, imagem 2 %32
      • Press and hold the power button for about 10 seconds, then release.
      • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
      Pergunte ao FixBot
      Comentar
    1. Dell Optiplex GX620 Floppy Drive Replacement, Dell Optiplex GX620 Side Panel Disassembly: passo 3, imagem 1 %32
      • With the computer standing upright, firmly pull on the tab at the back of the computer.
      • When the side panel pops free, gently pull the panel away from the computer.
      • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
      Pergunte ao FixBot
      Comentar
    1. Dell Optiplex GX620 Floppy Drive Replacement, Remove the drive panel: passo 4, imagem 1 %32
      • Slide the blue latch downward until the panel can be removed from it's hinges.
      Pergunte ao FixBot
      Comentar
    2. Dell Optiplex GX620 Floppy Drive Replacement, Disconnect the cables: passo 5, imagem 1 %32
      • Gently remove the floppy-drive and power cables from the back of the floppy drive.
      Pergunte ao FixBot
      Comentar
    3. Dell Optiplex GX620 Floppy Drive Replacement, Remove the screws: passo 6, imagem 1 %32
      • With a Phillips #1 screwdriver, remove the screws connecting the floppy drive to the drive bay. Set the screws aside in a location where you may use them at a later time.
      Pergunte ao FixBot
      Comentar
    4. Dell Optiplex GX620 Floppy Drive Replacement, Remove the floppy drive: passo 7, imagem 1 %32
      • To remove the unconnected floppy drive from the drive bay, slide the drive towards the front of the computer.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Kristina
Membro desde: 09/03/14
213 Reputação
Autoria de 7 guias
Equipe
Pasco Hernando, Team 5-1, Prince Fall 2014 Membro de Pasco Hernando, Team 5-1, Prince Fall 2014
PHSC-PRINCE-F14S5G1
10 Membros
Autoria de 22 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 16
Ao todo: 2,017
