Ir para o conteúdo principal
Dell Latitude E7270 Solid State Drive Replacement
O que você precisa
  1. Dell Latitude E7270 Solid State Drive Replacement, Back Panel: passo 1, imagem 1 %32
    • Place the device top down in front of you so that the vents are visible and are furthest from the user.
    • Please be sure that the device is powered off and unplugged before removing parts or deconstructing anything.
  2. Dell Latitude E7270 Solid State Drive Replacement: passo 2, imagem 1 %32
    • Remove all eight M2.5 X 8MM screws with a Phillips #00 screwdriver.
  3. Dell Latitude E7270 Solid State Drive Replacement: passo 3, imagem 1 %32
    • Lift and remove the panel.
  4. Dell Latitude E7270 Solid State Drive Replacement, Battery: passo 4, imagem 1 %32
    • Remove the three M2.5 X 5MM screws, located above the battery, with a Phillips #00 screwdriver.
  5. Dell Latitude E7270 Solid State Drive Replacement: passo 5, imagem 1 %32 Dell Latitude E7270 Solid State Drive Replacement: passo 5, imagem 2 %32
    • Disconnect the battery wire by using your fingers to pull diagonally left on the tab.
  6. Dell Latitude E7270 Solid State Drive Replacement: passo 6, imagem 1 %32
    • Remove the battery completely by grabbing an edge and pulling up on the battery.
  7. Dell Latitude E7270 Solid State Drive Replacement, Solid State Drive: passo 7, imagem 1 %32
    • Locate the SSD stick on the bottom right of the device.
    • In the absence of an SSD, a RAM stick was used as a substitute for visual and educational purposes only. The SSD in your device will resemble a RAM stick but may differ in color.
  8. Dell Latitude E7270 Solid State Drive Replacement: passo 8, imagem 1 %32
    • Slide the SSD of its socket.
Conclusão
Um comentário
Thumbs down for showing a memory module and not a SSD.
Christopher Gehringer - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 23
Últimos 30 dias: 72
Ao todo: 4,467
