Ir para o conteúdo principal
Dell Latitude D620 RAM Replacement
O que você precisa
    1. Dell Latitude D620 RAM Replacement, Keyboard: passo 1, imagem 1 %32
      • Power down the laptop and remove the battery.
      • Open the laptop cover all of the way.
      Pergunte ao FixBot
      Comentar
    2. Dell Latitude D620 RAM Replacement: passo 2, imagem 1 %32 Dell Latitude D620 RAM Replacement: passo 2, imagem 2 %32 Dell Latitude D620 RAM Replacement: passo 2, imagem 3 %32
      • Locate the notch under the cover at the top of the keyboard
      • Using the spudger as a lever, lift the plastic covering
      • Carefully remove the rest of the covering from right to left
      Pergunte ao FixBot
      Comentar
    3. Dell Latitude D620 RAM Replacement: passo 3, imagem 1 %32
      • Unscrew the top portion of the keyboard using a #00 screwdriver
      Pergunte ao FixBot
      Comentar
    4. Dell Latitude D620 RAM Replacement: passo 4, imagem 1 %32
      • Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
      • Don't pull on the keyboard too forcefully because it is attached to the motherboard with a short, thin ribbon cable
      Pergunte ao FixBot
      Comentar
    5. Dell Latitude D620 RAM Replacement: passo 5, imagem 1 %32 Dell Latitude D620 RAM Replacement: passo 5, imagem 2 %32
      • Once keyboard is out of the case, lay it face-down on the track pad
      Pergunte ao FixBot
      Comentar
    6. Dell Latitude D620 RAM Replacement: passo 6, imagem 1 %32 Dell Latitude D620 RAM Replacement: passo 6, imagem 2 %32
      • Using a small spudger, pull back on the black bar to release the blue lever
      Pergunte ao FixBot
      Comentar
    7. Dell Latitude D620 RAM Replacement: passo 7, imagem 1 %32
      • Pull up on the metal bar connected to the socket to detach the ribbon cable
      Pergunte ao FixBot
      Comentar
    1. Dell Latitude D620 RAM Replacement, RAM: passo 8, imagem 1 %32 Dell Latitude D620 RAM Replacement, RAM: passo 8, imagem 2 %32
      • With the keyboard removed, you should be able to see ram slot A.
      • Place new ram into the slot making sure it is aligned
      Pergunte ao FixBot
      Comentar
    2. Dell Latitude D620 RAM Replacement: passo 9, imagem 1 %32
      • Replace the keyboard by following the previous steps in reverse
      • Close the laptop, and flip it over onto its backside
      Pergunte ao FixBot
      Comentar
    3. Dell Latitude D620 RAM Replacement: passo 10, imagem 1 %32 Dell Latitude D620 RAM Replacement: passo 10, imagem 2 %32
      • Loosen the screw that holds the RAM cover in place.
      • The screw cannot be fully removed since it is attached to the RAM cover.
      Pergunte ao FixBot
      Comentar
    4. Dell Latitude D620 RAM Replacement: passo 11, imagem 1 %32 Dell Latitude D620 RAM Replacement: passo 11, imagem 2 %32
      • Insert new ram into slot B
      Pergunte ao FixBot
      Comentar
Conclusão
26 outras pessoas executaram este guia.
Miguel Wong
Membro desde: 04/15/10
565 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 24-35, Regan Spring 2010 Membro de Cal Poly, Team 24-35, Regan Spring 2010
CPSU-REGAN-S10S24G35
4 Membros
Autoria de 8 guias
2Comentários do guia
If you are increasing the amount of RAM installed -> On first power on after installing the RAM, system on boot up will complain about memory size changed, and to reseat the memory. Wait for about 60 - 90 seconds, and you will receive a few additional messages about F1 to continue or F2 for Setup. Go into Setup and verify that the system sees all memory installed. If installing 2 x 2GB DDR2, max possible, 4GB. BIOS setup should report 4GB installed, of which 3.37GB usable.
Michael Erwin - Responder Compartilhar
J’étais inquiet, mais en lisant votre commentaire, me voilà rassuré et j’ai donc suivi vos instructions. Ca fonctionne 2X2 GO …Merci
ppgauchard - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 64
Ao todo: 35,343
