Ir para o conteúdo principal
Dell Latitude D620 CD Drive Replacement
O que você precisa
    1. Dell Latitude D620 CD Drive Replacement, Keyboard: passo 1, imagem 1 %32
      • Power down the laptop and remove the battery.
      • Open the laptop cover all of the way.
      Pergunte ao FixBot
      Comentar
    2. Dell Latitude D620 CD Drive Replacement: passo 2, imagem 1 %32 Dell Latitude D620 CD Drive Replacement: passo 2, imagem 2 %32 Dell Latitude D620 CD Drive Replacement: passo 2, imagem 3 %32
      • Locate the notch under the cover at the top of the keyboard
      • Using the spudger as a lever, lift the plastic covering
      • Carefully remove the rest of the covering from right to left
      Pergunte ao FixBot
      Comentar
    3. Dell Latitude D620 CD Drive Replacement: passo 3, imagem 1 %32
      • Unscrew the top portion of the keyboard using a #00 screwdriver
      Pergunte ao FixBot
      Comentar
    4. Dell Latitude D620 CD Drive Replacement: passo 4, imagem 1 %32
      • Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
      • Don't pull on the keyboard too forcefully because it is attached to the motherboard with a short, thin ribbon cable
      Pergunte ao FixBot
      Comentar
    5. Dell Latitude D620 CD Drive Replacement: passo 5, imagem 1 %32 Dell Latitude D620 CD Drive Replacement: passo 5, imagem 2 %32
      • Once keyboard is out of the case, lay it face-down on the track pad
      Pergunte ao FixBot
      Comentar
    6. Dell Latitude D620 CD Drive Replacement: passo 6, imagem 1 %32 Dell Latitude D620 CD Drive Replacement: passo 6, imagem 2 %32
      • Using a small spudger, pull back on the black bar to release the blue lever
      Pergunte ao FixBot
      Comentar
    7. Dell Latitude D620 CD Drive Replacement: passo 7, imagem 1 %32
      • Pull up on the metal bar connected to the socket to detach the ribbon cable
      Pergunte ao FixBot
      Comentar
    1. Dell Latitude D620 CD Drive Replacement, CD Drive: passo 8, imagem 1 %32 Dell Latitude D620 CD Drive Replacement, CD Drive: passo 8, imagem 2 %32
      • Press in the tab on the bottom right side of the CD drive
      • The tab comes out on its own; there is no need to pull it out manually.
      Pergunte ao FixBot
      Comentar
    2. Dell Latitude D620 CD Drive Replacement: passo 9, imagem 1 %32
      • Gently pull the tab to remove the disk tray.
      Pergunte ao FixBot
      Comentar
Conclusão
10 outras pessoas executaram este guia.
Ivan
Membro desde: 04/15/10
203 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 24-35, Regan Spring 2010 Membro de Cal Poly, Team 24-35, Regan Spring 2010
CPSU-REGAN-S10S24G35
4 Membros
Autoria de 28 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 60
Ao todo: 9,059
