Ir para o conteúdo principal
Dell Latitude 9410 2-in-1 SSD Replacement
O que você precisa
  1. Dell Latitude 9410 2-in-1 SSD Replacement, Base Panel: passo 1, imagem 1 %32
    • Ensure that the laptop is unplugged and powered off before beginning.
    • Place the laptop upside down on a flat surface.
  2. Dell Latitude 9410 2-in-1 SSD Replacement: passo 2, imagem 1 %32 Dell Latitude 9410 2-in-1 SSD Replacement: passo 2, imagem 2 %32
    • Use a Phillips #00 screwdriver to loosen the ten captive screws.
    • The screws are permanently fastened to the base panel; do not attempt to remove them.
  3. Dell Latitude 9410 2-in-1 SSD Replacement: passo 3, imagem 1 %32 Dell Latitude 9410 2-in-1 SSD Replacement: passo 3, imagem 2 %32 Dell Latitude 9410 2-in-1 SSD Replacement: passo 3, imagem 3 %32
    • Carefully lift off the back panel.
  4. Dell Latitude 9410 2-in-1 SSD Replacement, SSD: passo 4, imagem 1 %32 Dell Latitude 9410 2-in-1 SSD Replacement, SSD: passo 4, imagem 2 %32 Dell Latitude 9410 2-in-1 SSD Replacement, SSD: passo 4, imagem 3 %32
    • Carefully peel back and remove the black tape around the top left corner of the motherboard.
  5. Dell Latitude 9410 2-in-1 SSD Replacement: passo 5, imagem 1 %32 Dell Latitude 9410 2-in-1 SSD Replacement: passo 5, imagem 2 %32 Dell Latitude 9410 2-in-1 SSD Replacement: passo 5, imagem 3 %32
    • Use a Phillips #00 screwdriver to remove the 2 mm screw, loosening the bracket that covers the SSD.
    • Carefully lift the off the bracket.
    • The bracket is attached to the laptop and cannot be removed completely.
  6. Dell Latitude 9410 2-in-1 SSD Replacement: passo 6, imagem 1 %32 Dell Latitude 9410 2-in-1 SSD Replacement: passo 6, imagem 2 %32 Dell Latitude 9410 2-in-1 SSD Replacement: passo 6, imagem 3 %32
    • Grip the SSD and pull directly backward until the SSD releases from its port.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 21
Ao todo: 1,478
