Ir para o conteúdo principal
Dell Latitude 9410 2-in-1 CMOS Battery Replacement
O que você precisa
  1. Dell Latitude 9410 2-in-1 CMOS Battery Replacement, Base Panel: passo 1, imagem 1 %32
    • Ensure that the laptop is unplugged and powered off before beginning.
    • Place the laptop upside down on a flat surface.
  2. Dell Latitude 9410 2-in-1 CMOS Battery Replacement: passo 2, imagem 1 %32 Dell Latitude 9410 2-in-1 CMOS Battery Replacement: passo 2, imagem 2 %32
    • Use a Phillips #00 screwdriver to loosen the ten captive screws.
    • The screws are permanently fastened to the base panel; do not attempt to remove them.
  3. Dell Latitude 9410 2-in-1 CMOS Battery Replacement: passo 3, imagem 1 %32 Dell Latitude 9410 2-in-1 CMOS Battery Replacement: passo 3, imagem 2 %32 Dell Latitude 9410 2-in-1 CMOS Battery Replacement: passo 3, imagem 3 %32
    • Carefully lift off the back panel.
  4. Dell Latitude 9410 2-in-1 CMOS Battery Replacement, CMOS Battery: passo 4, imagem 1 %32 Dell Latitude 9410 2-in-1 CMOS Battery Replacement, CMOS Battery: passo 4, imagem 2 %32 Dell Latitude 9410 2-in-1 CMOS Battery Replacement, CMOS Battery: passo 4, imagem 3 %32
    • Carefully peel back and remove the black tape around the top left corner of the motherboard.
  5. Dell Latitude 9410 2-in-1 CMOS Battery Replacement: passo 5, imagem 1 %32 Dell Latitude 9410 2-in-1 CMOS Battery Replacement: passo 5, imagem 2 %32 Dell Latitude 9410 2-in-1 CMOS Battery Replacement: passo 5, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Grip the CMOS cable as close as possible to the plug, and gently pull directly backwards, in the direction of the cables, until the CMOS cable disconnects from the motherboard.
    • If the cable is hard to pull out by hand, use tweezers to get a better grip on the cable connector.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 31
Duração total: 765
