Introdução
Use this guide to replace the coin cell battery (CMOS) of the Dell Latitude 9410 2-in-1.
If your computer runs slow, receives “Booting Error” messages, or loses BIOS settings when turned off, the CMOS may need to be replaced. The typical CMOS lifespan is 3-5 years, so if you're experiencing issues related to a failing CMOS, it's likely time to replace it. Be sure to check the troubleshooting page before moving forward with replacement.
O que você precisa
Carefully peel back and remove the black tape around the top left corner of the motherboard.
