Ir para o conteúdo principal
Dell Latitude 7410 SSD Replacement
O que você precisa
  1. Dell Latitude 7410 SSD Replacement, Prepare your laptop for disassembly: passo 1, imagem 1 %32
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables, fully shut down your laptop, and close the lid.
  2. Dell Latitude 7410 SSD Replacement, Unfasten the back cover: passo 2, imagem 1 %32
    • Use a Phillips screwdriver to loosen the eight captive screws securing the back cover.
  3. Dell Latitude 7410 SSD Replacement, Insert an opening pick: passo 3, imagem 1 %32 Dell Latitude 7410 SSD Replacement, Insert an opening pick: passo 3, imagem 2 %32
    • Insert an opening pick between the right edge of the back cover and the frame, just below the middle right screw.
  4. Dell Latitude 7410 SSD Replacement, Unclip the right edge: passo 4, imagem 1 %32 Dell Latitude 7410 SSD Replacement, Unclip the right edge: passo 4, imagem 2 %32
    • Slide your pick along the right edge to release the clips securing the back cover.
  5. Dell Latitude 7410 SSD Replacement, Unclip the left edge: passo 5, imagem 1 %32 Dell Latitude 7410 SSD Replacement, Unclip the left edge: passo 5, imagem 2 %32 Dell Latitude 7410 SSD Replacement, Unclip the left edge: passo 5, imagem 3 %32
    • Insert your pick between the left edge of the back cover and the frame, next to the speaker cutout.
    • Slide your pick along the left edge to release the clips.
  6. Dell Latitude 7410 SSD Replacement, Unclip the back edge: passo 6, imagem 1 %32 Dell Latitude 7410 SSD Replacement, Unclip the back edge: passo 6, imagem 2 %32 Dell Latitude 7410 SSD Replacement, Unclip the back edge: passo 6, imagem 3 %32
    • Insert your pick between the back cover and the right display-hinge to release the first clip along the back edge.
    • Slide your pick toward the left hinge until the second clip releases.
  7. Dell Latitude 7410 SSD Replacement, Unclip the front edge: passo 7, imagem 1 %32 Dell Latitude 7410 SSD Replacement, Unclip the front edge: passo 7, imagem 2 %32
    • Insert your pick between the front edge of the back cover and the frame, just to the right of the bottom left screw.
    • Slide your pick toward the right edge until the front edge releases from the frame.
  8. Dell Latitude 7410 SSD Replacement, Remove the back cover: passo 8, imagem 1 %32 Dell Latitude 7410 SSD Replacement, Remove the back cover: passo 8, imagem 2 %32
    • Remove the back cover.
  9. Dell Latitude 7410 SSD Replacement, Disconnect the battery: passo 9, imagem 1 %32 Dell Latitude 7410 SSD Replacement, Disconnect the battery: passo 9, imagem 2 %32
    • Grab the black pull tab on the head of the battery connector and pull straight up to disconnect it.
  10. Dell Latitude 7410 SSD Replacement, Remove the SSD shield: passo 10, imagem 1 %32 Dell Latitude 7410 SSD Replacement, Remove the SSD shield: passo 10, imagem 2 %32 Dell Latitude 7410 SSD Replacement, Remove the SSD shield: passo 10, imagem 3 %32
    • Use your Phillips screwdriver to remove the 2.7 mm screw securing the SSD shield.
    • Grab and remove the SSD shield.
  11. Dell Latitude 7410 SSD Replacement, Unfasten the SSD: passo 11, imagem 1 %32
    • Use your Phillips screwdriver to remove the 3 mm screw securing the SSD.
  12. Dell Latitude 7410 SSD Replacement, Remove the SSD: passo 12, imagem 1 %32 Dell Latitude 7410 SSD Replacement, Remove the SSD: passo 12, imagem 2 %32 Dell Latitude 7410 SSD Replacement, Remove the SSD: passo 12, imagem 3 %32
    • The socket doesn't spring up the SSD like in some laptops—keep the SSD flat to the laptop when removing or inserting it to prevent damage to the socket.
    • Grip the corners of the SSD closest to the screw cutout and pull it straight out of its socket and remove it.
    • If the SSD feels stuck, slightly wiggle it side-to-side as you pull.
Conclusão
Clay Eickemeyer
Membro desde: 09/19/22
95.712 Reputação
Autoria de 466 guias
Equipe
Guide Team Membro de Guide Team
Staff
10 Membros
Autoria de 15.889 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 69
Ao todo: 1,881
