Introdução
The purpose of this guide is to inform the reader on how to properly remove the RAM from their Dell Latitude 3310.
O que você precisa
Remove seven 8.0 mm screws using a Phillips #1 screwdriver.
Remove three 5.0 mm screws using a Phillips #1 screwdriver.
Lift the plastic cover up to expose the memory chipset.
Carefully pull the clips away from the chip to disengage them.
