Ir para o conteúdo principal
Dell Latitude 3189 Battery Replacement
O que você precisa
  1. Dell Latitude 3189 Battery Replacement, Lower Case: passo 1, imagem 1 %32 Dell Latitude 3189 Battery Replacement, Lower Case: passo 1, imagem 2 %32
    • Before beginning, power off and unplug the device.
    • Use a Phillips screwdriver to loosen the seven captive screws that secure the lower case.
  2. Dell Latitude 3189 Battery Replacement: passo 2, imagem 1 %32 Dell Latitude 3189 Battery Replacement: passo 2, imagem 2 %32 Dell Latitude 3189 Battery Replacement: passo 2, imagem 3 %32
    • Insert a nylon spudger between the lower case and chassis at the two hinge spaces on the back side of the laptop and pry up the lower case.
    • Do not use metal items to pry the base cover off, like a screwdriver, as it could slip and damage internal components.
    • Avoid prying at the ports.
  3. Dell Latitude 3189 Battery Replacement: passo 3, imagem 1 %32 Dell Latitude 3189 Battery Replacement: passo 3, imagem 2 %32
    • Grip and lift the lower case up and away.
    • If you feel any significant resistance, double check that all of the screws are loosened.
  4. Dell Latitude 3189 Battery Replacement: passo 4, imagem 1 %32 Dell Latitude 3189 Battery Replacement: passo 4, imagem 2 %32 Dell Latitude 3189 Battery Replacement: passo 4, imagem 3 %32
    • Before performing any operations within the laptop, unplug the battery.
    • Pull the white battery connector directly out of its motherboard port.
    • Do not pull on the wires.
  5. Dell Latitude 3189 Battery Replacement, Battery: passo 5, imagem 1 %32 Dell Latitude 3189 Battery Replacement, Battery: passo 5, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the three 3.2 mm screws that secure the battery.
  6. Dell Latitude 3189 Battery Replacement: passo 6, imagem 1 %32 Dell Latitude 3189 Battery Replacement: passo 6, imagem 2 %32
    • Grip the battery and lift it up and out of the chassis.
Conclusão
For optimal performance, calibrate your newly installed battery after completing this guide.
Uma outra pessoa concluiu este guia.
Bryan Pratt
Membro desde: 02/14/24
601 Reputação
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 16
Duração total: 73
