Ir para o conteúdo principal
Dell Inspiron N5030 RAM Replacement
O que você precisa
  1. Dell Inspiron N5030 RAM Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron N5030 RAM Replacement, Battery: passo 1, imagem 2 %32
    • Turn the computer over on its back so the battery compartment faces towards you.
    • Place your fingers on the small buttons with arrows pointing outwards.
    • Push and slide the buttons outward to unlock the battery compartment.
    Pergunte ao FixBot
    Comentar
  2. Dell Inspiron N5030 RAM Replacement: passo 2, imagem 1 %32 Dell Inspiron N5030 RAM Replacement: passo 2, imagem 2 %32
    • Grab the battery and pull it towards yourself.
    • Remove the battery.
    Pergunte ao FixBot
    Comentar
  3. Dell Inspiron N5030 RAM Replacement, Keyboard: passo 3, imagem 1 %32
    • Use a Phillips #0 screwdriver to unscrew the sixteen 0.6 mm screws on the back panel.
    Pergunte ao FixBot
    Comentar
  4. Dell Inspiron N5030 RAM Replacement: passo 4, imagem 1 %32
    • Flip over the laptop and open it so that the screen faces you.
    Pergunte ao FixBot
    Comentar
  5. Dell Inspiron N5030 RAM Replacement: passo 5, imagem 1 %32
    • Use the plastic opening tool and your fingers to pry off the top panel.
    • Pry the panel off starting at any one of the corners and then continue around the edges of the computer.
    Pergunte ao FixBot
    Comentar
  6. Dell Inspiron N5030 RAM Replacement: passo 6, imagem 1 %32
    • Be careful when lifting off the keyboard panel. There are multiple delicate cables connecting the panel to the motherboard.
    • Pull up on the blue plastic tab connected by the white strip to unhook the keyboard panel from the motherboard.
    Pergunte ao FixBot
    Comentar
  7. Dell Inspiron N5030 RAM Replacement: passo 7, imagem 1 %32
    • Flip up the small locking flap on the keyboard cable ZIF socket and disconnect the keyboard ribbon cable.
    Pergunte ao FixBot
    Comentar
  8. Dell Inspiron N5030 RAM Replacement: passo 8, imagem 1 %32
    • Pull up on the wire tab with the blue, white, black, and red wires to detach the speakers from the motherboard.
    Pergunte ao FixBot
    Comentar
  9. Dell Inspiron N5030 RAM Replacement: passo 9, imagem 1 %32
    • Remove the top keyboard panel.
    Pergunte ao FixBot
    Comentar
  10. Dell Inspiron N5030 RAM Replacement, RAM: passo 10, imagem 1 %32
    • Place your fingers on the two metal tabs on the edges of the RAM.
    • Push on the tabs in the opposite direction.
    • The top RAM board will pop up after you push on the metal tabs.
    Pergunte ao FixBot
    Comentar
  11. Dell Inspiron N5030 RAM Replacement: passo 11, imagem 1 %32
    • Pull the top RAM board out with your fingers.
    Pergunte ao FixBot
    Comentar
  12. Dell Inspiron N5030 RAM Replacement: passo 12, imagem 1 %32 Dell Inspiron N5030 RAM Replacement: passo 12, imagem 2 %32 Dell Inspiron N5030 RAM Replacement: passo 12, imagem 3 %32
    • Repeat the above RAM board steps for the second RAM board.
    Pergunte ao FixBot
    Comentar
Conclusão
5 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 10-59, Amido Spring 2014 Membro de Cal Poly, Team 10-59, Amido Spring 2014
CPSU-AMIDO-S14S10G59
4 Membros
Autoria de 5 guias
3Comentários do guia
Looking at the Dell service manual. You dont need to remove any screws, but only the keyboard, and if your careful you dont need to remove the ribbon cable. Its all in the service manual you can download free from Dell.
swestonj - Responder Compartilhar
swestonj is incorrect. The manual clearly states that you must remove the screws:
Service Manual
Removing the Keyboard
1. Follow the instructions in Before You Begin.
2. Remove the battery (see Removing the Battery).
3. Remove the two screws that secure the keyboard to the computer base.
etc.
mike - Responder Compartilhar
зависит от целей. озу можно поменять не разбирая всё. а вот пзу придется все разобрать. я так и не понял сьёмный тут проц или припаян. вроде есть защелка
артемий Александровна троицкий - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 35
Ao todo: 6,081
