Ir para o conteúdo principal
Dell Inspiron N5030 Disc Drive Replacement
O que você precisa
  1. Dell Inspiron N5030 Disc Drive Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron N5030 Disc Drive Replacement, Battery: passo 1, imagem 2 %32
    • Turn the computer over on its back so the battery compartment faces towards you.
    • Place your fingers on the small buttons with arrows pointing outwards.
    • Push and slide the buttons outward to unlock the battery compartment.
    Pergunte ao FixBot
    Comentar
  2. Dell Inspiron N5030 Disc Drive Replacement: passo 2, imagem 1 %32 Dell Inspiron N5030 Disc Drive Replacement: passo 2, imagem 2 %32
    • Grab the battery and pull it towards yourself.
    • Remove the battery.
    Pergunte ao FixBot
    Comentar
  3. Dell Inspiron N5030 Disc Drive Replacement, Keyboard: passo 3, imagem 1 %32
    • Use a Phillips #0 screwdriver to unscrew the sixteen 0.6 mm screws on the back panel.
    Pergunte ao FixBot
    Comentar
  4. Dell Inspiron N5030 Disc Drive Replacement: passo 4, imagem 1 %32
    • Flip over the laptop and open it so that the screen faces you.
    Pergunte ao FixBot
    Comentar
  5. Dell Inspiron N5030 Disc Drive Replacement: passo 5, imagem 1 %32
    • Use the plastic opening tool and your fingers to pry off the top panel.
    • Pry the panel off starting at any one of the corners and then continue around the edges of the computer.
    Pergunte ao FixBot
    Comentar
  6. Dell Inspiron N5030 Disc Drive Replacement: passo 6, imagem 1 %32
    • Be careful when lifting off the keyboard panel. There are multiple delicate cables connecting the panel to the motherboard.
    • Pull up on the blue plastic tab connected by the white strip to unhook the keyboard panel from the motherboard.
    Pergunte ao FixBot
    Comentar
  7. Dell Inspiron N5030 Disc Drive Replacement: passo 7, imagem 1 %32
    • Flip up the small locking flap on the keyboard cable ZIF socket and disconnect the keyboard ribbon cable.
    Pergunte ao FixBot
    Comentar
  8. Dell Inspiron N5030 Disc Drive Replacement: passo 8, imagem 1 %32
    • Pull up on the wire tab with the blue, white, black, and red wires to detach the speakers from the motherboard.
    Pergunte ao FixBot
    Comentar
  9. Dell Inspiron N5030 Disc Drive Replacement: passo 9, imagem 1 %32
    • Remove the top keyboard panel.
    Pergunte ao FixBot
    Comentar
  10. Dell Inspiron N5030 Disc Drive Replacement, Disc Drive: passo 10, imagem 1 %32
    • Use a Phillips #0 screwdriver to unscrew one 0.6 mm screw located just to the left of the disc drive.
    Pergunte ao FixBot
    Comentar
  11. Dell Inspiron N5030 Disc Drive Replacement: passo 11, imagem 1 %32
    • Position your thumbs to push firmly and slide the disc drive to the right through the rectangular hole in the side of the laptop and out.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Charles
Membro desde: 04/22/14
582 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 10-59, Amido Spring 2014 Membro de Cal Poly, Team 10-59, Amido Spring 2014
CPSU-AMIDO-S14S10G59
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 23
Ao todo: 2,335
