Ir para o conteúdo principal
Dell Inspiron 9300 Video Card Replacement
O que você precisa
  1. Dell Inspiron 9300 Video Card Replacement, Prerequisite Only: passo 1, imagem 1 %32 Dell Inspiron 9300 Video Card Replacement, Prerequisite Only: passo 1, imagem 2 %32
    • Remove the battery prior to working on any internal components.
    • Remove the twelve 6mm Phillips screws from the bottom of the case.
    • Remove the battery before working on internal components to ensure a safe working environment.
    Pergunte ao FixBot
    Comentar
  2. Dell Inspiron 9300 Video Card Replacement: passo 2, imagem 1 %32
    • Gently pry away the silver bezel above the keyboard and below the display using a spudger.
    • Start on the right hand side, where there is a notch in the bezel for easiest removal.
    Pergunte ao FixBot
    Comentar
  3. Dell Inspiron 9300 Video Card Replacement: passo 3, imagem 1 %32 Dell Inspiron 9300 Video Card Replacement: passo 3, imagem 2 %32 Dell Inspiron 9300 Video Card Replacement: passo 3, imagem 3 %32
    • Remove the two 5mm Phillips screws retaining the keyboard.
    • Pull the keyboard up and toward the monitor to reveal the ribbon cable beneath.
    • Firmly grasp the blue tape attached to the keyboard ribbon cable connector and pull upward away from the motherboard.
    Pergunte ao FixBot
    Comentar
  4. Dell Inspiron 9300 Video Card Replacement: passo 4, imagem 1 %32 Dell Inspiron 9300 Video Card Replacement: passo 4, imagem 2 %32
    • Firmly grasp the blue tape attached to the LCD display ribbon cable connector and pull upward away from the motherboard.
    • Remove the two 5mm Phillips screws holding the display hinge on both sides of the laptop.
    • Support the display as you loosen the hinges, to avoid the screen falling and breaking.
    Pergunte ao FixBot
    Comentar
  5. Dell Inspiron 9300 Video Card Replacement: passo 5, imagem 1 %32 Dell Inspiron 9300 Video Card Replacement: passo 5, imagem 2 %32
    • Remove the seven 6mm Phillips screws holding the trackpad/palm rest to the motherboard.
    • Gently pry the CMOS battery out of its retaining clip using a spudger.
    Pergunte ao FixBot
    Comentar
  6. Dell Inspiron 9300 Video Card Replacement: passo 6, imagem 1 %32 Dell Inspiron 9300 Video Card Replacement: passo 6, imagem 2 %32
    • Remove the low profile connector for the keyboard status lights located next to the video card heat sink using a spudger.
    • Remove the trackpad ribbon cable from the motherboard using a spudger.
    Pergunte ao FixBot
    Comentar
  7. Dell Inspiron 9300 Video Card Replacement: passo 7, imagem 1 %32 Dell Inspiron 9300 Video Card Replacement: passo 7, imagem 2 %32
    • Pull up and away on the track pad to expose the internal components below.
    Pergunte ao FixBot
    Comentar
  8. Dell Inspiron 9300 Video Card Replacement, Video Card: passo 8, imagem 1 %32
    • Loosen the four 5mm Phillips screws holding the video card and heatsink in place
    • The screws are held in place with retainer clips and are not fully removable
    Pergunte ao FixBot
    Comentar
  9. Dell Inspiron 9300 Video Card Replacement: passo 9, imagem 1 %32
    • Firmly pull up to unseat the video card from the motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Steven Faulkner
Membro desde: 11/10/16
490 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 16-6, Eyestone Fall 2016 Membro de USF Tampa, Team 16-6, Eyestone Fall 2016
USFT-EYESTONE-F16S16G6
5 Membros
Autoria de 11 guias
1Comentário do guia
This works only up to the point of pull up and away on the trackpad. The trackpad won't pull up.
cobrachoppergirl - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 34
Ao todo: 1,240
