Ir para o conteúdo principal
Dell Inspiron 9300 Trackpad Replacement
O que você precisa
  1. Dell Inspiron 9300 Trackpad Replacement, Trackpad: passo 1, imagem 1 %32
    • Remove the battery in to order avoid damaging internal components.
    Pergunte ao FixBot
    Comentar
  2. Dell Inspiron 9300 Trackpad Replacement: passo 2, imagem 1 %32
    • Remove the twelve 6mm Phillips screws from the bottom of the case.
    Pergunte ao FixBot
    Comentar
  3. Dell Inspiron 9300 Trackpad Replacement: passo 3, imagem 1 %32
    • Gently pry away the silver bezel above the keyboard and below the display using a spudger.
    • There is a notch on the right-hand side of the bezel for easiest removal.
    Pergunte ao FixBot
    Comentar
  4. Dell Inspiron 9300 Trackpad Replacement: passo 4, imagem 1 %32 Dell Inspiron 9300 Trackpad Replacement: passo 4, imagem 2 %32 Dell Inspiron 9300 Trackpad Replacement: passo 4, imagem 3 %32
    • Remove the two 5mm Phillips screws retaining the keyboard.
    • Pull the keyboard up and toward the monitor to reveal the ribbon cable beneath.
    • Firmly grasp the blue tape attached to the keyboard ribbon cable connector and pull upward, away from the motherboard.
    Pergunte ao FixBot
    Comentar
  5. Dell Inspiron 9300 Trackpad Replacement: passo 5, imagem 1 %32 Dell Inspiron 9300 Trackpad Replacement: passo 5, imagem 2 %32
    • Firmly grasp the blue tape attached to the LCD display ribbon cable connector and pull upward away from the motherboard.
    • Remove the two 5mm Phillips screws holding the display hinge on both sides of the laptop.
    • Support the display as you loosen the hinges, to avoid the screen falling and breaking.
    Pergunte ao FixBot
    Comentar
  6. Dell Inspiron 9300 Trackpad Replacement: passo 6, imagem 1 %32 Dell Inspiron 9300 Trackpad Replacement: passo 6, imagem 2 %32
    • Remove the seven 6mm Phillips screws holding the trackpad/palm rest to the motherboard.
    • Gently pry the CMOS battery out of its retaining clip using a spudger.
    Pergunte ao FixBot
    Comentar
  7. Dell Inspiron 9300 Trackpad Replacement: passo 7, imagem 1 %32 Dell Inspiron 9300 Trackpad Replacement: passo 7, imagem 2 %32
    • Remove the low profile connector for the keyboard status lights located next to the video card heat sink using a spudger.
    • Remove the trackpad ribbon cable from the motherboard using a spudger.
    Pergunte ao FixBot
    Comentar
  8. Dell Inspiron 9300 Trackpad Replacement: passo 8, imagem 1 %32
    • Pull up and away on the upper case to remove.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
USF Tampa, Team 16-6, Eyestone Fall 2016 Membro de USF Tampa, Team 16-6, Eyestone Fall 2016
USFT-EYESTONE-F16S16G6
5 Membros
Autoria de 11 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 23
Ao todo: 497
