Ir para o conteúdo principal
Dell Inspiron 9300 Keyboard Replacement
O que você precisa
  1. Dell Inspiron 9300 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Use the spudger to remove the top cover plate to expose the screws for the keyboard.
    • Be sure not to break the clips holding it in. Once the side has been lifted, gently lift the plate with your hand to remove it completely.
    Pergunte ao FixBot
    Comentar
  2. Dell Inspiron 9300 Keyboard Replacement: passo 2, imagem 1 %32
    • Remove the two 5mm Phillips screws holding the keyboard in place.
    Pergunte ao FixBot
    Comentar
  3. Dell Inspiron 9300 Keyboard Replacement: passo 3, imagem 1 %32
    • Pull the keyboard away from the laptop.
    • Be careful when pulling the keyboard not to damage the connecting ribbon underneath.
    Pergunte ao FixBot
    Comentar
  4. Dell Inspiron 9300 Keyboard Replacement: passo 4, imagem 1 %32 Dell Inspiron 9300 Keyboard Replacement: passo 4, imagem 2 %32
    • Gently pull up on the blue tab to disconnect the keyboard.
    • Pull the keyboard up and away to safely remove the keyboard.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Ady Alhamra
Membro desde: 09/26/16
149 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 16-6, Eyestone Fall 2016 Membro de USF Tampa, Team 16-6, Eyestone Fall 2016
USFT-EYESTONE-F16S16G6
5 Membros
Autoria de 11 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 32
Ao todo: 803
