Ir para o conteúdo principal
Dell Inspiron 9100 Memory Replacement
O que você precisa
  1. Dell Inspiron 9100 Memory Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 9100 Memory Replacement, Battery: passo 1, imagem 2 %32 Dell Inspiron 9100 Memory Replacement, Battery: passo 1, imagem 3 %32
    • Unplug the laptop from the power adapter and turn the power off.
    • Failure to unplug laptop before proceeding could result in risk of electric shock!
    Pergunte ao FixBot
    Comentar
  2. Dell Inspiron 9100 Memory Replacement: passo 2, imagem 1 %32 Dell Inspiron 9100 Memory Replacement: passo 2, imagem 2 %32 Dell Inspiron 9100 Memory Replacement: passo 2, imagem 3 %32
    • Slide the battery-lock tab and hold.
    • Flip the battery away from the chassis to remove it.
    Pergunte ao FixBot
    Comentar
  3. Dell Inspiron 9100 Memory Replacement, Memory: passo 3, imagem 1 %32 Dell Inspiron 9100 Memory Replacement, Memory: passo 3, imagem 2 %32
    • Using the Philips #00 screwdriver, undo the screw on the memory module cover, labeled "M."
    • This screw will remain in the panel.
    • Pull the cover away from the laptop using your finger.
    Pergunte ao FixBot
    Comentar
  4. Dell Inspiron 9100 Memory Replacement: passo 4, imagem 1 %32 Dell Inspiron 9100 Memory Replacement: passo 4, imagem 2 %32 Dell Inspiron 9100 Memory Replacement: passo 4, imagem 3 %32
    • Use your fingertips to carefully spread apart the plastic white tabs.
    • Flip the RAM up at a 45 degree angle and remove it.
    • Hold the RAM by the edges only.
    • Ground yourself while dealing with RAM. Static shock can damage the memory. Store the RAM in an anti-static bag while it is not in use.
    Pergunte ao FixBot
    Comentar
  5. Dell Inspiron 9100 Memory Replacement: passo 5, imagem 1 %32
    • Repeat step four with the second RAM.
    Pergunte ao FixBot
    Comentar
Conclusão
charlierefvem
Membro desde: 01/11/11
854 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 13-2, Forte Winter 2011 Membro de Cal Poly, Team 13-2, Forte Winter 2011
CPSU-FORTE-W11S13G2
5 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 29
Ao todo: 3,929
