Ir para o conteúdo principal
Dell Inspiron 8600 LCD Replacement
O que você precisa
  1. Dell Inspiron 8600 LCD Replacement, Hinge Cover: passo 1, imagem 1 %32 Dell Inspiron 8600 LCD Replacement, Hinge Cover: passo 1, imagem 2 %32 Dell Inspiron 8600 LCD Replacement, Hinge Cover: passo 1, imagem 3 %32
    • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
    • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
    • Be careful of the wire attached to the underside of the hinge cover.
    Pergunte ao FixBot
    Comentar
  2. Dell Inspiron 8600 LCD Replacement: passo 2, imagem 1 %32
    • Pull the small black tab on the right hand side of the laptop.
    • You have now removed the hinge cover.
    Pergunte ao FixBot
    Comentar
  3. Dell Inspiron 8600 LCD Replacement, Display Module: passo 3, imagem 1 %32 Dell Inspiron 8600 LCD Replacement, Display Module: passo 3, imagem 2 %32
    • Flip the laptop over and remove the indicated screws.
    • Flip the laptop back over.
    • Find the two places where the display module is attached to the base of the computer.
    Pergunte ao FixBot
    Comentar
  4. Dell Inspiron 8600 LCD Replacement: passo 4, imagem 1 %32
    • Disconnect the video card from the display module by gently lifting upwards on the black tab.
    Pergunte ao FixBot
    Comentar
  5. Dell Inspiron 8600 LCD Replacement: passo 5, imagem 1 %32 Dell Inspiron 8600 LCD Replacement: passo 5, imagem 2 %32
    • Lift the display module directly upwards from the base of the computer.
    Pergunte ao FixBot
    Comentar
  6. Dell Inspiron 8600 LCD Replacement: passo 6, imagem 1 %32
    • Now remove the display module.
    Pergunte ao FixBot
    Comentar
  7. Dell Inspiron 8600 LCD Replacement, LCD: passo 7, imagem 1 %32 Dell Inspiron 8600 LCD Replacement, LCD: passo 7, imagem 2 %32 Dell Inspiron 8600 LCD Replacement, LCD: passo 7, imagem 3 %32
    • First, remove the plastic tabs that are covering the interior screws.
    • After removing the tabs, remove the interior screws using a #1 Philips Screwdriver.
    • Note there are 8 tabs and 8 screws in total.
    Pergunte ao FixBot
    Comentar
  8. Dell Inspiron 8600 LCD Replacement: passo 8, imagem 1 %32
    • Now that the screws are removed, press the plastic casing inward to loosen the case. Then remove the plastic case from the monitor unit.
    Pergunte ao FixBot
    Comentar
  9. Dell Inspiron 8600 LCD Replacement: passo 9, imagem 1 %32
    • Using a Philips #1 screwdriver remove the screws holding the LCD in place.
    • Note there are 8 screws in total for this step, 4 on each side of the unit.
    Pergunte ao FixBot
    Comentar
  10. Dell Inspiron 8600 LCD Replacement: passo 10, imagem 1 %32
    • Remove the broken LCD unit, and replace with new unit.
    Pergunte ao FixBot
    Comentar
Conclusão
Perry
Membro desde: 04/12/11
251 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 18-22, Garner Spring 2011 Membro de Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 Membros
Autoria de 16 guias
1Comentário do guia
which controller board do i have to use for this model ?
bcdoor - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 21
Ao todo: 5,021
