Ir para o conteúdo principal
Dell Inspiron 6000 Screen Replacement
O que você precisa
  1. Dell Inspiron 6000 Screen Replacement, Battery: passo 1, imagem 1 %32
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Flip the laptop over, bottom-side up.
    Pergunte ao FixBot
    Comentar
  2. Dell Inspiron 6000 Screen Replacement: passo 2, imagem 1 %32
    • Push the switch next to the battery.
    • At the same time, lift the battery away from the laptop.
    Pergunte ao FixBot
    Comentar
  3. Dell Inspiron 6000 Screen Replacement, Keyboard: passo 3, imagem 1 %32 Dell Inspiron 6000 Screen Replacement, Keyboard: passo 3, imagem 2 %32 Dell Inspiron 6000 Screen Replacement, Keyboard: passo 3, imagem 3 %32
    • Place the laptop on flat surface.
    • Carefully open the laptop at far as it will go so that the back of screen is touching the flat surface.
    • Carefully take a spudger and separate part of the cover at the red circle.
    Pergunte ao FixBot
    Comentar
  4. Dell Inspiron 6000 Screen Replacement: passo 4, imagem 1 %32 Dell Inspiron 6000 Screen Replacement: passo 4, imagem 2 %32
    • Remove two 4 mm Philips #00 screws.
    Pergunte ao FixBot
    Comentar
  5. Dell Inspiron 6000 Screen Replacement: passo 5, imagem 1 %32
    • Gently lift the keyboard away from the laptop without harming the cord that is located at the bottom of the keyboard.
    Pergunte ao FixBot
    Comentar
  6. Dell Inspiron 6000 Screen Replacement: passo 6, imagem 1 %32 Dell Inspiron 6000 Screen Replacement: passo 6, imagem 2 %32 Dell Inspiron 6000 Screen Replacement: passo 6, imagem 3 %32
    • Gently pull the blue tab up until it comes away from computer.
    Pergunte ao FixBot
    Comentar
  7. Dell Inspiron 6000 Screen Replacement, Screen: passo 7, imagem 1 %32
    • Remove one 4mm Philips #00 screw to completely disengage blue tab.
    Pergunte ao FixBot
    Comentar
  8. Dell Inspiron 6000 Screen Replacement: passo 8, imagem 1 %32
    • Pull and disconnect the blue tab.
    Pergunte ao FixBot
    Comentar
  9. Dell Inspiron 6000 Screen Replacement: passo 9, imagem 1 %32
    • Disconnect the black and white wires.
    Pergunte ao FixBot
    Comentar
  10. Dell Inspiron 6000 Screen Replacement: passo 10, imagem 1 %32
    • Remove four 4mm Philips #00 screws at the hinges for the screen.
    Pergunte ao FixBot
    Comentar
  11. Dell Inspiron 6000 Screen Replacement: passo 11, imagem 1 %32
    • Separate the top panel of the laptop from the bottom panel.
    Pergunte ao FixBot
    Comentar
  12. Dell Inspiron 6000 Screen Replacement: passo 12, imagem 1 %32 Dell Inspiron 6000 Screen Replacement: passo 12, imagem 2 %32
    • Use the plastic opening tools to remove the six rubber screw covers in the corners.
    • Remove six 4 mm #00 Philips screws located in the corners.
    Pergunte ao FixBot
    Comentar
  13. Dell Inspiron 6000 Screen Replacement: passo 13, imagem 1 %32 Dell Inspiron 6000 Screen Replacement: passo 13, imagem 2 %32
    • Insert the plastic opening tools between the screen holders.
    • Go completely around the screen, separating the screen holders with the plastic opening tools.
    Pergunte ao FixBot
    Comentar
  14. Dell Inspiron 6000 Screen Replacement: passo 14, imagem 1 %32 Dell Inspiron 6000 Screen Replacement: passo 14, imagem 2 %32
    • Remove 12 4mm #00 Philips screws at the perimeter of the screen.
    Pergunte ao FixBot
    Comentar
  15. Dell Inspiron 6000 Screen Replacement: passo 15, imagem 1 %32 Dell Inspiron 6000 Screen Replacement: passo 15, imagem 2 %32
    • Gently lift the screen from the holder.
    • Do not touch the copper part of the bottom side of the screen.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Jacob DeWar
Membro desde: 09/23/14
563 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 11-1, Blackwell Fall 2014 Membro de USF Tampa, Team 11-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G1
5 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 32
Ao todo: 3,071
