Ir para o conteúdo principal
Dell Inspiron 5758 Heatsink and Fan Replacement
O que você precisa
  1. Dell Inspiron 5758 Heatsink and Fan Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 5758 Heatsink and Fan Replacement, Battery: passo 1, imagem 2 %32
    • Flip the laptop with the serial number facing up. You should be able to see the battery release switch.
  2. Dell Inspiron 5758 Heatsink and Fan Replacement: passo 2, imagem 1 %32 Dell Inspiron 5758 Heatsink and Fan Replacement: passo 2, imagem 2 %32 Dell Inspiron 5758 Heatsink and Fan Replacement: passo 2, imagem 3 %32
    • Slide the battery release switch towards the unlock icon.
    • You should hear a click.
    • Lift and pull the ejected battery to remove it.
  3. Dell Inspiron 5758 Heatsink and Fan Replacement, DC Jack: passo 3, imagem 1 %32 Dell Inspiron 5758 Heatsink and Fan Replacement, DC Jack: passo 3, imagem 2 %32 Dell Inspiron 5758 Heatsink and Fan Replacement, DC Jack: passo 3, imagem 3 %32
    • Remove the one 3mm optical drive screw.
    • Remove the two 8 mm screws.
    • Pry up and remove the access door.
  4. Dell Inspiron 5758 Heatsink and Fan Replacement: passo 4, imagem 1 %32
    • Remove the one 3 mm screw.
    • Remove the bracket.
  5. Dell Inspiron 5758 Heatsink and Fan Replacement: passo 5, imagem 1 %32 Dell Inspiron 5758 Heatsink and Fan Replacement: passo 5, imagem 2 %32
    • Unplug the antenna cables.
    • Remove the Wireless Card.
  6. Dell Inspiron 5758 Heatsink and Fan Replacement: passo 6, imagem 1 %32 Dell Inspiron 5758 Heatsink and Fan Replacement: passo 6, imagem 2 %32
    • Unplug the hard drive cable.
    • Use a plastic opening tool or your fingernail to pop the tab of the cable connector. Then you will be able to disconnect the cable.
    • Remove the four 8 mm screws.
    • Remove the hard drive.
  7. Dell Inspiron 5758 Heatsink and Fan Replacement: passo 7, imagem 1 %32 Dell Inspiron 5758 Heatsink and Fan Replacement: passo 7, imagem 2 %32 Dell Inspiron 5758 Heatsink and Fan Replacement: passo 7, imagem 3 %32
    • Remove the two 3 mm screws under the battery.
    • Remove the three 2 mm wafer screws under the optical drive.
    • Remove the ten 8 mm base screws.
  8. Dell Inspiron 5758 Heatsink and Fan Replacement: passo 8, imagem 1 %32
    • Unplug the speaker cable by sliding to the right.
  9. Dell Inspiron 5758 Heatsink and Fan Replacement: passo 9, imagem 1 %32 Dell Inspiron 5758 Heatsink and Fan Replacement: passo 9, imagem 2 %32
    • Press in the tabs to loosen the keyboard.
    • Carefully lift the keyboard up and turn it over.
  10. Dell Inspiron 5758 Heatsink and Fan Replacement: passo 10, imagem 1 %32
    • Unplug the keyboard cable & remove the keyboard.
  11. Dell Inspiron 5758 Heatsink and Fan Replacement: passo 11, imagem 1 %32 Dell Inspiron 5758 Heatsink and Fan Replacement: passo 11, imagem 2 %32
    • Slide the DVD optical drive over & remove it from the laptop.
  12. Dell Inspiron 5758 Heatsink and Fan Replacement: passo 12, imagem 1 %32 Dell Inspiron 5758 Heatsink and Fan Replacement: passo 12, imagem 2 %32
    • Remove the four 5 mm screws.
    • Unplug the optical drive interposer cable.
  13. Dell Inspiron 5758 Heatsink and Fan Replacement: passo 13, imagem 1 %32 Dell Inspiron 5758 Heatsink and Fan Replacement: passo 13, imagem 2 %32
    • Unplug the power button cable.
    • Unplug the touchpad cable.
  14. Dell Inspiron 5758 Heatsink and Fan Replacement: passo 14, imagem 1 %32 Dell Inspiron 5758 Heatsink and Fan Replacement: passo 14, imagem 2 %32 Dell Inspiron 5758 Heatsink and Fan Replacement: passo 14, imagem 3 %32
    • Carefully pry off & loosen the bottom base.
  15. Dell Inspiron 5758 Heatsink and Fan Replacement: passo 15, imagem 1 %32
    • Remove the bottom base.
  16. Dell Inspiron 5758 Heatsink and Fan Replacement: passo 16, imagem 1 %32 Dell Inspiron 5758 Heatsink and Fan Replacement: passo 16, imagem 2 %32
    • Remove the one 5mm screw.
    • Lift the circuit board & turn it over.
    • Unplug the cable.
    • Remove the audio/USB circuit board.
  17. Dell Inspiron 5758 Heatsink and Fan Replacement: passo 17, imagem 1 %32 Dell Inspiron 5758 Heatsink and Fan Replacement: passo 17, imagem 2 %32 Dell Inspiron 5758 Heatsink and Fan Replacement: passo 17, imagem 3 %32
    • Loosen the audio / USB cable.
    • Remove the one 3mm motherboard screw.
    • Lift the motherboard & carefully move it out of the way.
  18. Dell Inspiron 5758 Heatsink and Fan Replacement: passo 18, imagem 1 %32 Dell Inspiron 5758 Heatsink and Fan Replacement: passo 18, imagem 2 %32 Dell Inspiron 5758 Heatsink and Fan Replacement: passo 18, imagem 3 %32
    • Unplug the DC jack cable.
    • Remove the one 3mm screw.
    • Remove the DC Jack.
  19. Dell Inspiron 5758 Heatsink and Fan Replacement, Heatsink and Fan: passo 19, imagem 1 %32
    • After removing the bottom base, you can access the heatsink and fan, which is attached to the motherboard.
  20. Dell Inspiron 5758 Heatsink and Fan Replacement: passo 20, imagem 1 %32 Dell Inspiron 5758 Heatsink and Fan Replacement: passo 20, imagem 2 %32 Dell Inspiron 5758 Heatsink and Fan Replacement: passo 20, imagem 3 %32
    • Unplug the cable that connects the heatsink and fan to the motherboard.
  21. Dell Inspiron 5758 Heatsink and Fan Replacement: passo 21, imagem 1 %32 Dell Inspiron 5758 Heatsink and Fan Replacement: passo 21, imagem 2 %32
    • Loosen the three 5mm screws that connect the heatsink and fan to the motherboard.
    • The screws stay attached to the heatsink and fan. You cannot pull them out, only loosen them.
  22. Dell Inspiron 5758 Heatsink and Fan Replacement: passo 22, imagem 1 %32 Dell Inspiron 5758 Heatsink and Fan Replacement: passo 22, imagem 2 %32 Dell Inspiron 5758 Heatsink and Fan Replacement: passo 22, imagem 3 %32
    • Remove the heatsink and fan from the motherboard. You can now clean or replace it as you see fit.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 579
