Ir para o conteúdo principal
Dell Inspiron 3520 Screen Replacement
O que você precisa
    1. Dell Inspiron 3520 Screen Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 3520 Screen Replacement, Battery: passo 1, imagem 2 %32
      • Turn off notebook
      • Set the notebook upside down with the battery facing away from you.
      • Locate the unlock and release sliding tabs on the bottom right and left hand corners of the battery respectively.
      Pergunte ao FixBot
      Comentar
    2. Dell Inspiron 3520 Screen Replacement: passo 2, imagem 1 %32 Dell Inspiron 3520 Screen Replacement: passo 2, imagem 2 %32 Dell Inspiron 3520 Screen Replacement: passo 2, imagem 3 %32
      • Slide the right tab to the right to unlock the battery.
      • Slide and hold the the left tab to the left to release the battery from the unit.
      • Finally, remove the battery by sliding it away from the unit and yourself.
      Pergunte ao FixBot
      Comentar
    1. Dell Inspiron 3520 Screen Replacement, Keyboard: passo 3, imagem 1 %32 Dell Inspiron 3520 Screen Replacement, Keyboard: passo 3, imagem 2 %32
      • Locate the four tabs along the top edge of the keyboard.
      • Using the spudger, push the tabs away from the keyboard and pull the keyboard up away from the laptop.
      Pergunte ao FixBot
      Comentar
    2. Dell Inspiron 3520 Screen Replacement: passo 4, imagem 1 %32
      • Slide the keyboard forward towards the screen to release the bottom tabs.
      Pergunte ao FixBot
      Comentar
    3. Dell Inspiron 3520 Screen Replacement: passo 5, imagem 1 %32 Dell Inspiron 3520 Screen Replacement: passo 5, imagem 2 %32
      • Carefully lift the board up and locate the connecting cable.
      • Gently pull the end of the cable free from the port on the laptop.
      Pergunte ao FixBot
      Comentar
    1. Dell Inspiron 3520 Screen Replacement, Screen: passo 6, imagem 1 %32 Dell Inspiron 3520 Screen Replacement, Screen: passo 6, imagem 2 %32 Dell Inspiron 3520 Screen Replacement, Screen: passo 6, imagem 3 %32
      • Locate and remove the 14 (5mm) Phillips #00 screws from the bottom of the laptop.
      • Locate and remove the two 5mm Phillips #00 screws found under the keyboard.
      • Disconnect the two controlling wires with the blue pull tabs.
      Pergunte ao FixBot
      Comentar
    2. Dell Inspiron 3520 Screen Replacement: passo 7, imagem 1 %32 Dell Inspiron 3520 Screen Replacement: passo 7, imagem 2 %32 Dell Inspiron 3520 Screen Replacement: passo 7, imagem 3 %32
      • Using the spudger, carefully work your way around the edge of the upper shell.
      • Lift the upper shell away from the laptop.
      • Close the laptop and remove the casing over the hinge using the spudger.
      Pergunte ao FixBot
      Comentar
    3. Dell Inspiron 3520 Screen Replacement: passo 8, imagem 1 %32 Dell Inspiron 3520 Screen Replacement: passo 8, imagem 2 %32 Dell Inspiron 3520 Screen Replacement: passo 8, imagem 3 %32
      • Gently pull the cable located near the fan free from its dock.
      • Just behind the optical drive locate the 4mm Phillps #00 mounting screw for the small circuit board and remove it.
      • The board should then pull free.
      • Take note of how the cables fit along the ridge for when it comes to reassembly.
      Pergunte ao FixBot
      Comentar
    4. Dell Inspiron 3520 Screen Replacement: passo 9, imagem 1 %32 Dell Inspiron 3520 Screen Replacement: passo 9, imagem 2 %32
      • Open the laptop and locate the two hinges.
      • Each hinge has two 5mm Phillips #00 screws that need to be removed.
      • With the screws removed the screen should pull free.
      Pergunte ao FixBot
      Comentar
Conclusão
6 outras pessoas executaram este guia.
Ian
Membro desde: 01/30/15
1.638 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 16-2, Watkins Winter 2015 Membro de USF Tampa, Team 16-2, Watkins Winter 2015
USFT-WATKINS-W15S16G2
3 Membros
Autoria de 5 guias
1Comentário do guia
These instructions are not for screen replacement
Ryan Zulu - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 66
Ao todo: 7,122
