Ir para o conteúdo principal
Dell Inspiron 3520 RAM Replacement
O que você precisa
    1. Dell Inspiron 3520 RAM Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 3520 RAM Replacement, Battery: passo 1, imagem 2 %32
      • Turn off notebook
      • Set the notebook upside down with the battery facing away from you.
      • Locate the unlock and release sliding tabs on the bottom right and left hand corners of the battery respectively.
      Pergunte ao FixBot
      Comentar
    2. Dell Inspiron 3520 RAM Replacement: passo 2, imagem 1 %32 Dell Inspiron 3520 RAM Replacement: passo 2, imagem 2 %32 Dell Inspiron 3520 RAM Replacement: passo 2, imagem 3 %32
      • Slide the right tab to the right to unlock the battery.
      • Slide and hold the the left tab to the left to release the battery from the unit.
      • Finally, remove the battery by sliding it away from the unit and yourself.
      Pergunte ao FixBot
      Comentar
    1. Dell Inspiron 3520 RAM Replacement, Keyboard: passo 3, imagem 1 %32 Dell Inspiron 3520 RAM Replacement, Keyboard: passo 3, imagem 2 %32
      • Locate the four tabs along the top edge of the keyboard.
      • Using the spudger, push the tabs away from the keyboard and pull the keyboard up away from the laptop.
      Pergunte ao FixBot
      Comentar
    2. Dell Inspiron 3520 RAM Replacement: passo 4, imagem 1 %32
      • Slide the keyboard forward towards the screen to release the bottom tabs.
      Pergunte ao FixBot
      Comentar
    3. Dell Inspiron 3520 RAM Replacement: passo 5, imagem 1 %32 Dell Inspiron 3520 RAM Replacement: passo 5, imagem 2 %32
      • Carefully lift the board up and locate the connecting cable.
      • Gently pull the end of the cable free from the port on the laptop.
      Pergunte ao FixBot
      Comentar
    1. Dell Inspiron 3520 RAM Replacement, RAM: passo 6, imagem 1 %32
      • Locate the RAM chip(s)
      • There are no RAM chips present in this photo.
      Pergunte ao FixBot
      Comentar
    2. Dell Inspiron 3520 RAM Replacement: passo 7, imagem 1 %32 Dell Inspiron 3520 RAM Replacement: passo 7, imagem 2 %32
      • There are two connecting pins for the lower chip.
      • There are two connecting pins for the upper chip.
      • Pull the pins away from the sides of the chip(s) to release it.
      • The chip(s) should slide away from the dock easily.
      Pergunte ao FixBot
      Comentar
Conclusão
18 outras pessoas executaram este guia.
Ian
Membro desde: 01/30/15
1.638 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 16-2, Watkins Winter 2015 Membro de USF Tampa, Team 16-2, Watkins Winter 2015
USFT-WATKINS-W15S16G2
3 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 14
Últimos 30 dias: 58
Ao todo: 33,621
