Ir para o conteúdo principal
Dell Inspiron 3520 Optical Drive Replacement
O que você precisa
    1. Dell Inspiron 3520 Optical Drive Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 3520 Optical Drive Replacement, Battery: passo 1, imagem 2 %32
      • Turn off notebook
      • Set the notebook upside down with the battery facing away from you.
      • Locate the unlock and release sliding tabs on the bottom right and left hand corners of the battery respectively.
      Pergunte ao FixBot
      Comentar
    2. Dell Inspiron 3520 Optical Drive Replacement: passo 2, imagem 1 %32 Dell Inspiron 3520 Optical Drive Replacement: passo 2, imagem 2 %32 Dell Inspiron 3520 Optical Drive Replacement: passo 2, imagem 3 %32
      • Slide the right tab to the right to unlock the battery.
      • Slide and hold the the left tab to the left to release the battery from the unit.
      • Finally, remove the battery by sliding it away from the unit and yourself.
      Pergunte ao FixBot
      Comentar
    1. Dell Inspiron 3520 Optical Drive Replacement, Keyboard: passo 3, imagem 1 %32 Dell Inspiron 3520 Optical Drive Replacement, Keyboard: passo 3, imagem 2 %32
      • Locate the four tabs along the top edge of the keyboard.
      • Using the spudger, push the tabs away from the keyboard and pull the keyboard up away from the laptop.
      Pergunte ao FixBot
      Comentar
    2. Dell Inspiron 3520 Optical Drive Replacement: passo 4, imagem 1 %32
      • Slide the keyboard forward towards the screen to release the bottom tabs.
      Pergunte ao FixBot
      Comentar
    3. Dell Inspiron 3520 Optical Drive Replacement: passo 5, imagem 1 %32 Dell Inspiron 3520 Optical Drive Replacement: passo 5, imagem 2 %32
      • Carefully lift the board up and locate the connecting cable.
      • Gently pull the end of the cable free from the port on the laptop.
      Pergunte ao FixBot
      Comentar
    1. Dell Inspiron 3520 Optical Drive Replacement, Optical Drive: passo 6, imagem 1 %32 Dell Inspiron 3520 Optical Drive Replacement, Optical Drive: passo 6, imagem 2 %32
      • Locate and remove the 4mm Phillips #00 mounting screw.
      Pergunte ao FixBot
      Comentar
    2. Dell Inspiron 3520 Optical Drive Replacement: passo 7, imagem 1 %32 Dell Inspiron 3520 Optical Drive Replacement: passo 7, imagem 2 %32
      • Push the optical drive from the inside a little bit to dislodge it.
      • Grab the drive with your hand from the outside and slide it free.
      Pergunte ao FixBot
      Comentar
Conclusão
5 outras pessoas executaram este guia.
Ian
Membro desde: 01/30/15
1.638 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 16-2, Watkins Winter 2015 Membro de USF Tampa, Team 16-2, Watkins Winter 2015
USFT-WATKINS-W15S16G2
3 Membros
Autoria de 20 guias
1Comentário do guia
...screaming.....i love my dell 3520 it is awesome, it is still holding up.."hooray!!!!
Madeline Jones - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 30
Ao todo: 3,131
