Ir para o conteúdo principal
Dell Inspiron 3501 Back Cover Replacement
O que você precisa
  1. Dell Inspiron 3501 Back Cover Replacement, Unfasten the back cover: passo 1, imagem 1 %32 Dell Inspiron 3501 Back Cover Replacement, Unfasten the back cover: passo 1, imagem 2 %32
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use the Phillips screwdriver to remove the seven 6 mm-long screws securing the back cover.
    • Use the Phillips screwdriver to loosen the two captive screws.
  2. Dell Inspiron 3501 Back Cover Replacement, Unclip the front corners: passo 2, imagem 1 %32 Dell Inspiron 3501 Back Cover Replacement, Unclip the front corners: passo 2, imagem 2 %32
    • Insert an opening pick between the bottom-left corner of the back cover and the laptop body.
    • Pry upward to release the retaining clips.
    • Listen for a click sound when each clip releases.
    • Repeat this procedure for the bottom-right corner of the back cover.
  3. Dell Inspiron 3501 Back Cover Replacement, Unclip the sides: passo 3, imagem 1 %32 Dell Inspiron 3501 Back Cover Replacement, Unclip the sides: passo 3, imagem 2 %32
    • At the sides of the laptop, insert your opening pick between the cover and body.
    • Pry upward to release the remainder of the clips.
  4. Dell Inspiron 3501 Back Cover Replacement, Remove the back cover: passo 4, imagem 1 %32 Dell Inspiron 3501 Back Cover Replacement, Remove the back cover: passo 4, imagem 2 %32 Dell Inspiron 3501 Back Cover Replacement, Remove the back cover: passo 4, imagem 3 %32
    • Grab the cover by the edge closest to you.
    • Lift the cover up. Swing it open so that the rear edge lifts up last.
    • Completely remove the cover from the laptop.
    • If the back cover is stuck to laptop body, use an opening pick to slide around the perimeter of the back cover to release any remaining clips.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Dell Inspiron answers community for help.
Clay Eickemeyer
Membro desde: 09/19/22
82.120 Reputação
Autoria de 455 guias
Equipe
Guide Team Membro de Guide Team
Staff
9 Membros
Autoria de 11.442 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 17
Últimos 30 dias: 63
Ao todo: 1,569
