Ir para o conteúdo principal
Dell Inspiron 1721 Keyboard Replacement
O que você precisa
  1. Dell Inspiron 1721 Keyboard Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 1721 Keyboard Replacement, Battery: passo 1, imagem 2 %32
    • Slide tabs outward to undo the locks.
    • Grab and pull the battery away from the device to remove.
  2. Dell Inspiron 1721 Keyboard Replacement, Hinge Plate Cover: passo 2, imagem 1 %32 Dell Inspiron 1721 Keyboard Replacement, Hinge Plate Cover: passo 2, imagem 2 %32 Dell Inspiron 1721 Keyboard Replacement, Hinge Plate Cover: passo 2, imagem 3 %32
    • Pry up on the corner of the hinge cover with an iFixit opening tool.
    • Use the iFixit opening tool along both sides and the front of the hinge cover to release it.
    • Lean the display back as far as it goes and lift up on the hinge cover to remove.
  3. Dell Inspiron 1721 Keyboard Replacement, Keyboard: passo 3, imagem 1 %32 Dell Inspiron 1721 Keyboard Replacement, Keyboard: passo 3, imagem 2 %32 Dell Inspiron 1721 Keyboard Replacement, Keyboard: passo 3, imagem 3 %32
    • Remove four 3mm Phillips #1 screws from the top of the keyboard.
    • Use an iFixit opening tool to slide the keyboard upwards toward the display.
    • Slide the keyboard until it is clear of the lock tab, and lift it up to remove.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Duração total: 265
