Ir para o conteúdo principal
Dell Inspiron 1721 Hinge Plate Cover Replacement
O que você precisa
  1. Dell Inspiron 1721 Hinge Plate Cover Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 1721 Hinge Plate Cover Replacement, Battery: passo 1, imagem 2 %32
    • Slide tabs outward to undo the locks.
    • Grab and pull the battery away from the device to remove.
  2. Dell Inspiron 1721 Hinge Plate Cover Replacement, Hinge Plate Cover: passo 2, imagem 1 %32 Dell Inspiron 1721 Hinge Plate Cover Replacement, Hinge Plate Cover: passo 2, imagem 2 %32 Dell Inspiron 1721 Hinge Plate Cover Replacement, Hinge Plate Cover: passo 2, imagem 3 %32
    • Pry up on the corner of the hinge cover with an iFixit opening tool.
    • Use the iFixit opening tool along both sides and the front of the hinge cover to release it.
    • Lean the display back as far as it goes and lift up on the hinge cover to remove.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 152
