Ir para o conteúdo principal
Dell Inspiron 1545 Keyboard Replacement
O que você precisa
  1. Dell Inspiron 1545 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Turn the laptop over to its back.
    Pergunte ao FixBot
    Comentar
  2. Dell Inspiron 1545 Keyboard Replacement: passo 2, imagem 1 %32
    • Slide the release latch while simultaneously pulling backwards on the battery.
    Pergunte ao FixBot
    Comentar
  3. Dell Inspiron 1545 Keyboard Replacement: passo 3, imagem 1 %32
    • Slide the battery out of the battery bay.
    Pergunte ao FixBot
    Comentar
  4. Dell Inspiron 1545 Keyboard Replacement, Base Cover: passo 4, imagem 1 %32
    • Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
    • The top 3 screws are "captive" (held in by a retaining ring) and will not come out.
    Pergunte ao FixBot
    Comentar
  5. Dell Inspiron 1545 Keyboard Replacement: passo 5, imagem 1 %32 Dell Inspiron 1545 Keyboard Replacement: passo 5, imagem 2 %32
    • Carefully lift the base cover vertically away from the laptop.
    Pergunte ao FixBot
    Comentar
  6. Dell Inspiron 1545 Keyboard Replacement, Center Control Cover: passo 6, imagem 1 %32
    • After removing the battery, remove the two screws (3mm Phillips #1) beneath it. These screws hold the Center Control Cover in place.
    Pergunte ao FixBot
    Comentar
  7. Dell Inspiron 1545 Keyboard Replacement: passo 7, imagem 1 %32
    • Flip the laptop over to the front and open the display as far as possible.
    Pergunte ao FixBot
    Comentar
  8. Dell Inspiron 1545 Keyboard Replacement: passo 8, imagem 1 %32 Dell Inspiron 1545 Keyboard Replacement: passo 8, imagem 2 %32 Dell Inspiron 1545 Keyboard Replacement: passo 8, imagem 3 %32
    • The Center Control Cover is VERY fragile, be careful when using prying tools.
    • Pry the Center Control Cover from the laptop. On the right there is a small divot, it is advised that you start removing the panel from here.
    • Carefully lift the Center Control Cover away from the laptop.
    Pergunte ao FixBot
    Comentar
  9. Dell Inspiron 1545 Keyboard Replacement, Keyboard: passo 9, imagem 1 %32
    • Remove the two screws (5mm Phillips #1) at the top of the keyboard.
    Pergunte ao FixBot
    Comentar
  10. Dell Inspiron 1545 Keyboard Replacement: passo 10, imagem 1 %32
    • Slide the keyboard out and away from the laptop and lift it up to access the keyboard connector.
    • Do not pull hard on the keyboard while removing it, you may damage the keyboard or the keyboard connector.
    Pergunte ao FixBot
    Comentar
  11. Dell Inspiron 1545 Keyboard Replacement: passo 11, imagem 1 %32
    • Lift the connector latch that secures the keyboard cable to the connector on the motherboard and remove the cable.
    Pergunte ao FixBot
    Comentar
  12. Dell Inspiron 1545 Keyboard Replacement: passo 12, imagem 1 %32
    • Lift the keyboard up and away from the laptop.
    Pergunte ao FixBot
    Comentar
Conclusão
15 outras pessoas executaram este guia.
Nathan Lemay
Membro desde: 04/16/14
3.160 Reputação
Autoria de 15 guias
Equipe
Cal Poly, Team 9-14, Regan Spring 2014 Membro de Cal Poly, Team 9-14, Regan Spring 2014
CPSU-REGAN-S14S9G14
4 Membros
Autoria de 15 guias
3Comentários do guia
Step 4 and 5 are not needed.
James Thrun - Responder Compartilhar
Steps 4 and 5 are unnecessary for removing the keyboard. Other than that, well done.
lee - Responder Compartilhar
The connector latch is broken. What should I do?
Mjeed - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 57
Ao todo: 7,965
