Ir para o conteúdo principal
Dell Inspiron 1545 Computer Processing Unit Replacement
O que você precisa
  1. Dell Inspiron 1545 Computer Processing Unit Replacement, Battery: passo 1, imagem 1 %32
    • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Turn the laptop over to its back.
    Pergunte ao FixBot
    Comentar
  2. Dell Inspiron 1545 Computer Processing Unit Replacement: passo 2, imagem 1 %32
    • Slide the release latch while simultaneously pulling backwards on the battery.
    Pergunte ao FixBot
    Comentar
  3. Dell Inspiron 1545 Computer Processing Unit Replacement: passo 3, imagem 1 %32
    • Slide the battery out of the battery bay.
    Pergunte ao FixBot
    Comentar
  4. Dell Inspiron 1545 Computer Processing Unit Replacement, Base Cover: passo 4, imagem 1 %32
    • Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
    • The top 3 screws are "captive" (held in by a retaining ring) and will not come out.
    Pergunte ao FixBot
    Comentar
  5. Dell Inspiron 1545 Computer Processing Unit Replacement: passo 5, imagem 1 %32 Dell Inspiron 1545 Computer Processing Unit Replacement: passo 5, imagem 2 %32
    • Carefully lift the base cover vertically away from the laptop.
    Pergunte ao FixBot
    Comentar
  6. Dell Inspiron 1545 Computer Processing Unit Replacement, CPU Heat Sink: passo 6, imagem 1 %32
    • Loosen the 5 screws (4mm, Phillips #1) that secure the CPU Heat Sink to the motherboard.
    • These screws are held in place by a washer so you should not be able to completely remove the screws.
    Pergunte ao FixBot
    Comentar
  7. Dell Inspiron 1545 Computer Processing Unit Replacement: passo 7, imagem 1 %32
    • Pull up on the Heat Sink unit to remove it.
    Pergunte ao FixBot
    Comentar
  8. Dell Inspiron 1545 Computer Processing Unit Replacement, Computer Processing Unit: passo 8, imagem 1 %32
    • Using a flathead screwdriver, rotate the locking mechanism counterclockwise to the unlocked position.
    Pergunte ao FixBot
    Comentar
  9. Dell Inspiron 1545 Computer Processing Unit Replacement: passo 9, imagem 1 %32
    • The CPU is very fragile and has thin pins.
    • Remove the CPU by pulling straight upward and away from the laptop.
    Pergunte ao FixBot
    Comentar
Conclusão
8 outras pessoas executaram este guia.
Nathan Lemay
Membro desde: 04/16/14
3.160 Reputação
Autoria de 15 guias
Equipe
Cal Poly, Team 9-14, Regan Spring 2014 Membro de Cal Poly, Team 9-14, Regan Spring 2014
CPSU-REGAN-S14S9G14
4 Membros
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 35
Ao todo: 3,276
