Ir para o conteúdo principal
Dell Inspiron 1526 Keyboard Replacement
O que você precisa
    1. Dell Inspiron 1526 Keyboard Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 1526 Keyboard Replacement, Battery: passo 1, imagem 2 %32 Dell Inspiron 1526 Keyboard Replacement, Battery: passo 1, imagem 3 %32
      • Slide the unlock button to the left to release the battery.
      • Slide the battery away from the laptop to remove.
      • The unlock button is located on the bottom of the laptop.
      Pergunte ao FixBot
      Comentar
    1. Dell Inspiron 1526 Keyboard Replacement, Keyboard: passo 2, imagem 1 %32
      • Loosen the two 3.5mm Phillips #1 screws in the battery bay.
      Pergunte ao FixBot
      Comentar
    2. Dell Inspiron 1526 Keyboard Replacement: passo 3, imagem 1 %32
      • Flip the laptop over.
      • Lift the control cover by prying the right side of the cover with an iFixit opening tool.
      Pergunte ao FixBot
      Comentar
    3. Dell Inspiron 1526 Keyboard Replacement: passo 4, imagem 1 %32
      • Carefully lift the control cover up and forward to reveal a single ribbon cable.
      Pergunte ao FixBot
      Comentar
    4. Dell Inspiron 1526 Keyboard Replacement: passo 5, imagem 1 %32
      Ferramenta utilizada neste passo:
      • Use tweezers to squeeze the tabs on the connector and remove the ribbon cable.
      Pergunte ao FixBot
      Comentar
    5. Dell Inspiron 1526 Keyboard Replacement: passo 6, imagem 1 %32 Dell Inspiron 1526 Keyboard Replacement: passo 6, imagem 2 %32
      • Remove the control cover.
      Pergunte ao FixBot
      Comentar
    6. Dell Inspiron 1526 Keyboard Replacement: passo 7, imagem 1 %32
      • Remove the two 3mm Phillips #1 screws at the top of the keyboard where the control cover was.
      Pergunte ao FixBot
      Comentar
    7. Dell Inspiron 1526 Keyboard Replacement: passo 8, imagem 1 %32
      • Lift the keyboard gently from the top, but do not remove completely.
      • Looking under the keyboard, towards the touch-pad in the center, lift up the black tab on the connector with tweezers for the keyboard ribbon cable.
      Pergunte ao FixBot
      Comentar
    8. Dell Inspiron 1526 Keyboard Replacement: passo 9, imagem 1 %32 Dell Inspiron 1526 Keyboard Replacement: passo 9, imagem 2 %32
      • Remove the keyboard.
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 13
Últimos 30 dias: 34
Ao todo: 451
