Ir para o conteúdo principal
Dell Inspiron 1525 Motherboard Replacement
O que você precisa
  1. Dell Inspiron 1525 Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron 1525 Motherboard Replacement: passo 2, imagem 1 %32 Dell Inspiron 1525 Motherboard Replacement: passo 2, imagem 2 %32
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron 1525 Motherboard Replacement, Central Control Cover: passo 3, imagem 1 %32
    • Remove the two 4.00 mm Phillips #1 screws from the battery tray.
  4. Dell Inspiron 1525 Motherboard Replacement: passo 4, imagem 1 %32 Dell Inspiron 1525 Motherboard Replacement: passo 4, imagem 2 %32 Dell Inspiron 1525 Motherboard Replacement: passo 4, imagem 3 %32
    • Insert the flat end of a spudger into the slot on the right side of the central control cover and pry it up.
    • Carefully pull the central control cover up along its edges.
    • Do not attempt to completely remove the cover, as it is still attached via a ribbon cable.
  5. Dell Inspiron 1525 Motherboard Replacement: passo 5, imagem 1 %32 Dell Inspiron 1525 Motherboard Replacement: passo 5, imagem 2 %32 Dell Inspiron 1525 Motherboard Replacement: passo 5, imagem 3 %32
    • Peel back the silver tape securing the ribbon cable to the cover.
    • Pull the small brown latch on the ribbon cable connector out.
    • Disconnect the ribbon cable to completely free the central control cover.
  6. Dell Inspiron 1525 Motherboard Replacement, Keyboard: passo 6, imagem 1 %32 Dell Inspiron 1525 Motherboard Replacement, Keyboard: passo 6, imagem 2 %32
    • Remove the two 5.75 mm Phillips #1 screws securing the keyboard to the laptop.
    • Gently slide the keyboard towards the display until the tabs on its front side are free.
    • Do not force the keyboard too far forward or attempt to remove it yet, as there is still a ribbon cable connected to it.
  7. Dell Inspiron 1525 Motherboard Replacement: passo 7, imagem 1 %32 Dell Inspiron 1525 Motherboard Replacement: passo 7, imagem 2 %32
    • Use a spudger to gently lift the ribbon cable retaining flap.
    • Disconnect the ribbon cable.
    • Shift the keyboard sideways enough to free one side from it's retaining tab. Then lift the keyboard away from the laptop.
  8. Dell Inspiron 1525 Motherboard Replacement, Hard Drive: passo 8, imagem 1 %32 Dell Inspiron 1525 Motherboard Replacement, Hard Drive: passo 8, imagem 2 %32 Dell Inspiron 1525 Motherboard Replacement, Hard Drive: passo 8, imagem 3 %32
    • Remove the two 3.60 mm #1 Phillips screws securing the hard drive and hard drive tray.
    • Slide the hard drive and hard drive tray out of the laptop.
  9. Dell Inspiron 1525 Motherboard Replacement, Optical Drive: passo 9, imagem 1 %32 Dell Inspiron 1525 Motherboard Replacement, Optical Drive: passo 9, imagem 2 %32
    • Remove the 5.75 mm #1 Phillips screw securing the optical drive.
    • Pull the optical drive straight from the laptop.
  10. Dell Inspiron 1525 Motherboard Replacement, Bottom Cover: passo 10, imagem 1 %32 Dell Inspiron 1525 Motherboard Replacement, Bottom Cover: passo 10, imagem 2 %32
    • Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
    • The screws may only need to be loosened, as they are generally retained by plastic washers.
    • Remove the bottom panel.
  11. Dell Inspiron 1525 Motherboard Replacement, Display Assembly: passo 11, imagem 1 %32 Dell Inspiron 1525 Motherboard Replacement, Display Assembly: passo 11, imagem 2 %32 Dell Inspiron 1525 Motherboard Replacement, Display Assembly: passo 11, imagem 3 %32
    • Disconnect the five antennas from their respective cards.
    • De-route the antennas from their routing retainers.
  12. Dell Inspiron 1525 Motherboard Replacement: passo 12, imagem 1 %32
    • Remove the two 5.70 mm Phillips #1 screws securing the display assembly to the bottom case half.
    • The screw holes will be denoted by an embossed "D" by the hole.
  13. Dell Inspiron 1525 Motherboard Replacement: passo 13, imagem 1 %32 Dell Inspiron 1525 Motherboard Replacement: passo 13, imagem 2 %32 Dell Inspiron 1525 Motherboard Replacement: passo 13, imagem 3 %32
    • Use the flat end of a spudger to push the camera connector out of its socket. Alternate pushing on either side to evenly remove the connector.
    • Carefully release the connector from its retaining tabs.
  14. Dell Inspiron 1525 Motherboard Replacement: passo 14, imagem 1 %32 Dell Inspiron 1525 Motherboard Replacement: passo 14, imagem 2 %32
    • Push the antenna wires up through their hole in the bottom case half.
    • Release the antennas from their retaining tabs on the upper case.
  15. Dell Inspiron 1525 Motherboard Replacement: passo 15, imagem 1 %32 Dell Inspiron 1525 Motherboard Replacement: passo 15, imagem 2 %32
    • Disconnect the flat LCD ribbon cable by pulling it up by the tab.
    • Free the ribbon cable from its retaining clips.
  16. Dell Inspiron 1525 Motherboard Replacement: passo 16, imagem 1 %32
    • Remove the four 3.45 mm Phillips #1 screws securing the display assembly to the laptop chassis.
    • Support the display assembly as you remove these screws to prevent damage to the screw and hole threads.
    • Remove the display assembly from the laptop.
  17. Dell Inspiron 1525 Motherboard Replacement, Upper Case: passo 17, imagem 1 %32 Dell Inspiron 1525 Motherboard Replacement, Upper Case: passo 17, imagem 2 %32
    • Remove the nine 5.75 mm Phillips #1 screws on the bottom side of the laptop.
    • Remove the two 5.70 mm Phillips #1 screws on the top side of the laptop.
  18. Dell Inspiron 1525 Motherboard Replacement: passo 18, imagem 1 %32 Dell Inspiron 1525 Motherboard Replacement: passo 18, imagem 2 %32
    • Use a spudger to pull the touch pad connector latch towards the ribbon cable.
    • Pull the ribbon cable out of the connector.
  19. Dell Inspiron 1525 Motherboard Replacement: passo 19, imagem 1 %32 Dell Inspiron 1525 Motherboard Replacement: passo 19, imagem 2 %32
    • Use a spudger to pull the device status LED connector latch towards the ribbon cable.
    • Disconnect the device status LED ribbon cable.
  20. Dell Inspiron 1525 Motherboard Replacement: passo 20, imagem 1 %32 Dell Inspiron 1525 Motherboard Replacement: passo 20, imagem 2 %32 Dell Inspiron 1525 Motherboard Replacement: passo 20, imagem 3 %32
    • Release the ribbon cable in the upper left corner of the laptop from its retaining tabs.
    • Use a spudger to unplug the speaker connector at the top center of the laptop.
    • De-route the speaker wires from their retaining tabs.
  21. Dell Inspiron 1525 Motherboard Replacement: passo 21, imagem 1 %32 Dell Inspiron 1525 Motherboard Replacement: passo 21, imagem 2 %32
    • Use the flat end of a spudger to begin lifting the upper case at its front edge.
    • Lift the front edge of the case up until it comes free.
    • Work slowly and be sure not to get any cables caught in the upper case holes and guides.
  22. Dell Inspiron 1525 Motherboard Replacement, ExpressCard Cage: passo 22, imagem 1 %32 Dell Inspiron 1525 Motherboard Replacement, ExpressCard Cage: passo 22, imagem 2 %32 Dell Inspiron 1525 Motherboard Replacement, ExpressCard Cage: passo 22, imagem 3 %32
    • Eject your ExpressCard or ExpressCard dust shield if you want to transfer it to the new ExpressCard cage. Eject the card by pressing it in until it clicks, releasing it, then sliding it out.
    • Remove the 3.80 mm Phillips #1 screw securing the ExpressCard cage.
    • Remove the two 3.70 mm Phillips #1 screws securing the ExpressCard cage.
    • Lift the ExpressCard cage out of its connector.
  23. Dell Inspiron 1525 Motherboard Replacement, Heat Sink: passo 23, imagem 1 %32 Dell Inspiron 1525 Motherboard Replacement, Heat Sink: passo 23, imagem 2 %32 Dell Inspiron 1525 Motherboard Replacement, Heat Sink: passo 23, imagem 3 %32
    • Loosen the five #1 Phillips screws securing the heat sink and clean it with compressed air
    • These screws are attached to the heat sink assembly.
    • Gently lift the heat sink from side indicated in the picture.
    • The heat sink may feel like it is glued to the chips because of the thermal paste. Gently wiggle the heat sink back and forth to help break it free.
    • Be sure to thoroughly clean off the old thermal paste and apply new thermal paste before reinstalling the heat sink. Follow our thermal paste application guide for detailed instructions.
  24. Dell Inspiron 1525 Motherboard Replacement, Motherboard: passo 24, imagem 1 %32 Dell Inspiron 1525 Motherboard Replacement, Motherboard: passo 24, imagem 2 %32
    • Use a spudger to push the retaining latch of the central control button connector towards its cable.
    • Pull the cable out of the connector.
  25. Dell Inspiron 1525 Motherboard Replacement: passo 25, imagem 1 %32 Dell Inspiron 1525 Motherboard Replacement: passo 25, imagem 2 %32
    • Pull the retaining latch for the wireless sniffer cable out.
    • Remove the cable from the connector.
  26. Dell Inspiron 1525 Motherboard Replacement: passo 26, imagem 1 %32 Dell Inspiron 1525 Motherboard Replacement: passo 26, imagem 2 %32
    • Disconnect the fan cable connector by pulling it towards the fan with a spudger.
  27. Dell Inspiron 1525 Motherboard Replacement: passo 27, imagem 1 %32 Dell Inspiron 1525 Motherboard Replacement: passo 27, imagem 2 %32 Dell Inspiron 1525 Motherboard Replacement: passo 27, imagem 3 %32
    • Remove the four 3.70 mm Phillips #1 screws securing the motherboard to the lower case.
    • Gently peel the front bezel off.
    • Lift the motherboard out of the lower case.
    • If you are installing a new motherboard, make sure to transfer any remaining cables onto the new motherboard, as well as the CPU, RAM, modem, and Wi-Fi card.
Conclusão
8 outras pessoas executaram este guia.
4 comentários
Thank you for these directions!!! They made the tedious job of replacing the motherboard in my Inspiron 1525 much easier....only had to remove the motherboard one extra time to remove the modem and WIFI modem off the back as well as one cable that wasn't mentioned or needed to just get the motherboard out...Thanks again!!!
fjr69 - Responder
Hey, thanks for the kind words. I added a note on the last step as a reminder for folks to transfer any remaining components onto the new motherboard!
Miroslav Djuric -
hi please help me.
my inspiron 1525 after fan starting turns fast and loud display gets dim.
what you think?
Emin - Responder
Thanks so much!!! This was perfect. I've never done anything like this before and you made it work!!!!
polly_jordan - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 18
Últimos 30 dias: 36
Duração total: 24,391
