Ir para o conteúdo principal
Dell Inspiron 1525 Heat Sink Replacement
O que você precisa
  1. Dell Inspiron 1525 Heat Sink Replacement, Battery: passo 1, imagem 1 %32
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron 1525 Heat Sink Replacement: passo 2, imagem 1 %32 Dell Inspiron 1525 Heat Sink Replacement: passo 2, imagem 2 %32
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron 1525 Heat Sink Replacement, Bottom Cover: passo 3, imagem 1 %32 Dell Inspiron 1525 Heat Sink Replacement, Bottom Cover: passo 3, imagem 2 %32
    • Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
    • The screws may only need to be loosened, as they are generally retained by plastic washers.
    • Remove the bottom panel.
  4. Dell Inspiron 1525 Heat Sink Replacement, Heat Sink: passo 4, imagem 1 %32 Dell Inspiron 1525 Heat Sink Replacement, Heat Sink: passo 4, imagem 2 %32 Dell Inspiron 1525 Heat Sink Replacement, Heat Sink: passo 4, imagem 3 %32
    • Loosen the five #1 Phillips screws securing the heat sink and clean it with compressed air
    • These screws are attached to the heat sink assembly.
    • Gently lift the heat sink from side indicated in the picture.
    • The heat sink may feel like it is glued to the chips because of the thermal paste. Gently wiggle the heat sink back and forth to help break it free.
    • Be sure to thoroughly clean off the old thermal paste and apply new thermal paste before reinstalling the heat sink. Follow our thermal paste application guide for detailed instructions.
Conclusão
5 outras pessoas executaram este guia.
Um comentário
Is there any option to modify the heatsink for better cooling
manashpratim saikia - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 21
Ao todo: 7,926
