Ir para o conteúdo principal
Dell Inspiron 15-7559 Battery Replacement
O que você precisa
  1. Dell Inspiron 15-7559 Battery Replacement, Back Panel: passo 1, imagem 1 %32
    • Turn off the computer.
    • Disconnect the charging cable from the computer.
    • Failure to turn off the device and disconnect the cable could lead to personal injury or device damage.
    • Flip the computer upside down.
  2. Dell Inspiron 15-7559 Battery Replacement: passo 2, imagem 1 %32 Dell Inspiron 15-7559 Battery Replacement: passo 2, imagem 2 %32 Dell Inspiron 15-7559 Battery Replacement: passo 2, imagem 3 %32
    • Remove the captive screw located on the top section of the back panel, using a Philips #1 screwdriver.
    • Keep in mind that the screw cannot be fully removed from the panel, even when fully loosened.
  3. Dell Inspiron 15-7559 Battery Replacement: passo 3, imagem 1 %32 Dell Inspiron 15-7559 Battery Replacement: passo 3, imagem 2 %32 Dell Inspiron 15-7559 Battery Replacement: passo 3, imagem 3 %32
    • Use the blue, plastic opening tool to gently pry a section of the back panel open.
    • Next slide the opening tool around the back panel to disconnect the clips holding the panel in place.
    • After the clips have been disconnected, the back panel can then be easily lifted off the computer.
  4. Dell Inspiron 15-7559 Battery Replacement, Battery: passo 4, imagem 1 %32
    • Locate the battery on the bottom left side of the laptop.
  5. Dell Inspiron 15-7559 Battery Replacement: passo 5, imagem 1 %32 Dell Inspiron 15-7559 Battery Replacement: passo 5, imagem 2 %32 Dell Inspiron 15-7559 Battery Replacement: passo 5, imagem 3 %32
    • Unscrew the 5 x 2mm x 5mm screws, using the T8 Torx screwdriver.
  6. Dell Inspiron 15-7559 Battery Replacement: passo 6, imagem 1 %32 Dell Inspiron 15-7559 Battery Replacement: passo 6, imagem 2 %32 Dell Inspiron 15-7559 Battery Replacement: passo 6, imagem 3 %32
    • Using the tab above the battery, raise the battery far enough to disconnect the cables attached to it.
    • Using your hand grab the white portion connecting the cables to the battery and disconnect it.
    • Do not pull on the cables directly. This would risk damaging them or tearing them from the device.
  7. Dell Inspiron 15-7559 Battery Replacement: passo 7, imagem 1 %32
    • Now lift the battery from the device to remove it.
Conclusão
11 outras pessoas executaram este guia.
Equipe
UW Tacoma, Team S3-G2, Liner Fall 2017 Membro de UW Tacoma, Team S3-G2, Liner Fall 2017
UWT-LINER-F17S3G2
Membros da 5
Autoria de 9 guias
2 comentários
Cool, that’s the easy part. How do you tell the UEFI that it’s okay to charge the new battery?
Stefan Bacon - Responder
is it ok to replace the 11.4V battery with the 11.1V version?
Payton DePietro - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 16
Últimos 30 dias: 77
Duração total: 16,459
