Ir para o conteúdo principal
Dell Inspiron 15-5567 Hard Drive Replacement
O que você precisa
  1. Dell Inspiron 15-5567 Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32 Dell Inspiron 15-5567 Hard Drive Replacement, Hard Drive: passo 1, imagem 2 %32 Dell Inspiron 15-5567 Hard Drive Replacement, Hard Drive: passo 1, imagem 3 %32
    • Power off the laptop and wait 20 minutes before beginning disassembly.
    • Use a Phillips #0 screwdriver to remove thirteen 8.5 mm screws from the bottom of the laptop.
    • Using the same screwdriver, remove the two 3.2 mm screws and slide the DVD drive out of the laptop.
  2. Dell Inspiron 15-5567 Hard Drive Replacement: passo 2, imagem 1 %32 Dell Inspiron 15-5567 Hard Drive Replacement: passo 2, imagem 2 %32 Dell Inspiron 15-5567 Hard Drive Replacement: passo 2, imagem 3 %32
    • Remove the three 2.3 mm screws underneath the CD drive using the Phillips #0 screwdriver.
    • Pry off the back cover of the laptop using an opening tool.
  3. Dell Inspiron 15-5567 Hard Drive Replacement: passo 3, imagem 1 %32 Dell Inspiron 15-5567 Hard Drive Replacement: passo 3, imagem 2 %32
    • Disconnect cable covering the hard drive by prying up on the clamp holding the cable.
    • Disconnect the cable from the motherboard.
  4. Dell Inspiron 15-5567 Hard Drive Replacement: passo 4, imagem 1 %32 Dell Inspiron 15-5567 Hard Drive Replacement: passo 4, imagem 2 %32
    • Using the Phillips #0 screwdriver, remove the three 5.6 mm screws from the hard drive.
    • Remove the old hard drive from the laptop.
Conclusão
3 outras pessoas executaram este guia.
Saaed Chaudhry
Membro desde: 07/15/20
478 Reputação
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 15
Últimos 30 dias: 40
Duração total: 2,584
