Ir para o conteúdo principal
Dell Inspiron 15-5567 CPU Fan Replacement
O que você precisa
  1. Dell Inspiron 15-5567 CPU Fan Replacement, Back Cover: passo 1, imagem 1 %32 Dell Inspiron 15-5567 CPU Fan Replacement, Back Cover: passo 1, imagem 2 %32 Dell Inspiron 15-5567 CPU Fan Replacement, Back Cover: passo 1, imagem 3 %32
    • Orient the laptop with the back cover facing upward and the INSPIRON engraving reads legible (not flipped).
    • Remove 13 M2.5x8mm screws using a Philips #0 screwdriver.
    • Remove two M2x4mm screws using the same screwdriver.
  2. Dell Inspiron 15-5567 CPU Fan Replacement: passo 2, imagem 1 %32 Dell Inspiron 15-5567 CPU Fan Replacement: passo 2, imagem 2 %32
    • Insert the blue plastic opening tool into the crease of the CD driver, and pop it open.
    • Slide the rest of it out with your hand.
  3. Dell Inspiron 15-5567 CPU Fan Replacement: passo 3, imagem 1 %32 Dell Inspiron 15-5567 CPU Fan Replacement: passo 3, imagem 2 %32 Dell Inspiron 15-5567 CPU Fan Replacement: passo 3, imagem 3 %32
    • Remove three M2x2mm screws underneath the CD driver with the same Philips #0 screwdriver.
    • Place the blue plastic opening tool in the crease of the cover and push it upward to open the back cover.
    • Grab the corners of the cover firmly and lift it up.
    • Some parts are weaker than others; open it gently from corners.
  4. Dell Inspiron 15-5567 CPU Fan Replacement, CPU Fan: passo 4, imagem 1 %32 Dell Inspiron 15-5567 CPU Fan Replacement, CPU Fan: passo 4, imagem 2 %32 Dell Inspiron 15-5567 CPU Fan Replacement, CPU Fan: passo 4, imagem 3 %32
    • Remove four M2.5x5mm screws from the fan using a Philips #0 screwdriver.
    • The four screws over the processor will not come off all the way, they'll just loosen up.
    • Remove the other four M2x3mm screws using a Philips #0 screwdriver.
    • Gently disconnect the fan cable from the motherboard using the blue plastic opening tool.
  5. Dell Inspiron 15-5567 CPU Fan Replacement: passo 5, imagem 1 %32
    • Lift the fan and its components up and remove it.
Conclusão
4 outras pessoas executaram este guia.
Um comentário
Warning, under the fan, a thin cable going to the CD drive was stuck with tape. I was able to remove it, but the connector did pull out of the motherboard, which took a bit of fiddling to get connected again.
Craig Treptow - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 68
Duração total: 5,387
