Ir para o conteúdo principal
Dell Inspiron 15-5565 Wireless Card Replacement
O que você precisa
  1. Dell Inspiron 15-5565 Wireless Card Replacement, Optical Drive: passo 1, imagem 1 %32
    • Remove the 4 mm screw that secures the optical drive bracket to the optical drive using a Phillips #00 screwdriver.
  2. Dell Inspiron 15-5565 Wireless Card Replacement: passo 2, imagem 1 %32 Dell Inspiron 15-5565 Wireless Card Replacement: passo 2, imagem 2 %32 Dell Inspiron 15-5565 Wireless Card Replacement: passo 2, imagem 3 %32
    • Eject the optical drive by pressing the eject button.
    • Push out the optical drive bracket using the iFixit opening tool.
  3. Dell Inspiron 15-5565 Wireless Card Replacement, Back Cover: passo 3, imagem 1 %32 Dell Inspiron 15-5565 Wireless Card Replacement, Back Cover: passo 3, imagem 2 %32
    • Remove 13 8 mm screws from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the single 4 mm screw from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the three 4 mm screws from the optical drive slot using a Phillips #00 screwdriver.
  4. Dell Inspiron 15-5565 Wireless Card Replacement: passo 4, imagem 1 %32 Dell Inspiron 15-5565 Wireless Card Replacement: passo 4, imagem 2 %32
    • Remove the back cover from the laptop.
  5. Dell Inspiron 15-5565 Wireless Card Replacement, Wireless Card: passo 5, imagem 1 %32 Dell Inspiron 15-5565 Wireless Card Replacement, Wireless Card: passo 5, imagem 2 %32
    • Remove the single screw securing the wireless card bracket using a Phillips #00 screwdriver.
    • Slide the bracket to remove it.
    • Disconnect the two cables from the wireless card.
  6. Dell Inspiron 15-5565 Wireless Card Replacement: passo 6, imagem 1 %32
    • Slide out the wireless card to remove it from its slot.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 109
