Ir para o conteúdo principal
Dell Inspiron 1420 Memory Module Replacement
O que você precisa
    1. Dell Inspiron 1420 Memory Module Replacement, Loosen the Screws: passo 1, imagem 1 %32
      • Follow the procedures in Before You Begin.
      • Turn the computer over.
      • Loosen the captive screws from the memory module cover.
      Pergunte ao FixBot
      Comentar
    2. Dell Inspiron 1420 Memory Module Replacement, Lifting the Cover: passo 2, imagem 1 %32
      • Lift the memory module cover and set it aside.
      • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
      Pergunte ao FixBot
      Comentar
    3. Dell Inspiron 1420 Memory Module Replacement, Popping up the Memory Module: passo 3, imagem 1 %32
      • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
      Pergunte ao FixBot
      Comentar
    4. Dell Inspiron 1420 Memory Module Replacement, Removing the Module: passo 4, imagem 1 %32
      • Remove the module from the connector.
      Pergunte ao FixBot
      Comentar
    5. Dell Inspiron 1420 Memory Module Replacement, Align the Notch: passo 5, imagem 1 %32
      • Align the notch in the module edge connector with the tab in the connector slot.
      Pergunte ao FixBot
      Comentar
    6. Dell Inspiron 1420 Memory Module Replacement, Sliding the Module: passo 6, imagem 1 %32
      • Slide the module firmly into the slot at a 30-degree angle, and rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
      • NOTE: If the memory module is not installed properly, the computer may not boot. No error message indicates this failure.
      Pergunte ao FixBot
      Comentar
    7. Dell Inspiron 1420 Memory Module Replacement, Replace the Module Cover: passo 7, imagem 1 %32 Dell Inspiron 1420 Memory Module Replacement, Replace the Module Cover: passo 7, imagem 2 %32
      • Replace the memory module cover and tighten the three captive screws.
      Pergunte ao FixBot
      Comentar
Linha de Chegada
Uma outra pessoa concluiu este guia.
Terrence15
Membro desde: 12/18/17
80.125 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
45 Membros
Autoria de 8.863 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 28
Ao todo: 553
