Ir para o conteúdo principal
Dell Inspiron 1420 Display Replacement
O que você precisa
    1. Dell Inspiron 1420 Display Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 1420 Display Replacement, Battery: passo 1, imagem 2 %32 Dell Inspiron 1420 Display Replacement, Battery: passo 1, imagem 3 %32
      • Slide the two tabs to release the battery.
      • Pull the battery out.
      Pergunte ao FixBot
      Comentar
    1. Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: passo 2, imagem 1 %32 Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: passo 2, imagem 2 %32 Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: passo 2, imagem 3 %32
      • Use a spudger to pry the 6 rubber bumpers from the display.
      • Using a Phillips #00 screwdriver, remove the six 4mm screws that are beneath the six rubber bumpers.
      Pergunte ao FixBot
      Comentar
    2. Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: passo 3, imagem 1 %32 Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: passo 3, imagem 2 %32 Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: passo 3, imagem 3 %32
      • Gently pry the frame using a spudger.
      • Using a Phillips #00 screwdriver, remove the two 5mm screws at the bottom of the screen.
      Pergunte ao FixBot
      Comentar
    3. Dell Inspiron 1420 Display Replacement, Separating the Display from the Frame: passo 4, imagem 1 %32 Dell Inspiron 1420 Display Replacement, Separating the Display from the Frame: passo 4, imagem 2 %32 Dell Inspiron 1420 Display Replacement, Separating the Display from the Frame: passo 4, imagem 3 %32
      • Use a spudger to loosen the frame from the top.
      • Lift up the black connector to detach the gold ribbon.
      Pergunte ao FixBot
      Comentar
    4. Dell Inspiron 1420 Display Replacement, Removing the Power Connector Cable: passo 5, imagem 1 %32 Dell Inspiron 1420 Display Replacement, Removing the Power Connector Cable: passo 5, imagem 2 %32
      • Pull directly up on the light blue tab.
      Pergunte ao FixBot
      Comentar
    5. Dell Inspiron 1420 Display Replacement, VGA cable: passo 6, imagem 1 %32 Dell Inspiron 1420 Display Replacement, VGA cable: passo 6, imagem 2 %32 Dell Inspiron 1420 Display Replacement, VGA cable: passo 6, imagem 3 %32
      • Squeeze the two metal clips located on the VGA cable.
      • Pull while squeezing the clips in order to remove the cable.
      Pergunte ao FixBot
      Comentar
    6. Dell Inspiron 1420 Display Replacement, Isolating the Display: passo 7, imagem 1 %32 Dell Inspiron 1420 Display Replacement, Isolating the Display: passo 7, imagem 2 %32 Dell Inspiron 1420 Display Replacement, Isolating the Display: passo 7, imagem 3 %32
      • Using a Phillips #00 screwdriver, remove the three 3mm screws located on both the left and right side of the laptop.
      • Remove the metal brackets, one on each side, by gently pulling.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 2-4, Blackwell Fall 2014 Membro de USF Tampa, Team 2-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G4
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 52
Ao todo: 2,974
