Ir para o conteúdo principal
Dell Inspiron 14 5100 Touch Pad Replacement
O que você precisa
  1. Dell Inspiron 14 5100 Touch Pad Replacement, Dell Inspiron 14 5100 Disassembly: passo 1, imagem 1 %32 Dell Inspiron 14 5100 Touch Pad Replacement, Dell Inspiron 14 5100 Disassembly: passo 1, imagem 2 %32 Dell Inspiron 14 5100 Touch Pad Replacement, Dell Inspiron 14 5100 Disassembly: passo 1, imagem 3 %32
    • Make sure to disconnect the power source to the device.
    • Remove nine screws securing the base cover of the laptop's keyboard assembly using the Phillips #0 screwdriver.
    • There are 2 sets of screws.
    • Remove the 3 captive screws.
    • Remove the 6M2*6 screws.
  2. Dell Inspiron 14 5100 Touch Pad Replacement: passo 2, imagem 1 %32 Dell Inspiron 14 5100 Touch Pad Replacement: passo 2, imagem 2 %32
    • Pry open the laptop to separate the base cover from the keyboard assembly.
    • You may use your fingertips or use plastic opening tools.
  3. Dell Inspiron 14 5100 Touch Pad Replacement, Battery: passo 3, imagem 1 %32 Dell Inspiron 14 5100 Touch Pad Replacement, Battery: passo 3, imagem 2 %32
    • Remove the four Phillips #0 screws securing the battery to the keyboard assembly.
  4. Dell Inspiron 14 5100 Touch Pad Replacement: passo 4, imagem 1 %32 Dell Inspiron 14 5100 Touch Pad Replacement: passo 4, imagem 2 %32 Dell Inspiron 14 5100 Touch Pad Replacement: passo 4, imagem 3 %32
    • Peel off the tape securing the battery cable to the battery cable connector.
    • Disconnect and remove the old battery.
  5. Dell Inspiron 14 5100 Touch Pad Replacement, Touch Pad: passo 5, imagem 1 %32 Dell Inspiron 14 5100 Touch Pad Replacement, Touch Pad: passo 5, imagem 2 %32 Dell Inspiron 14 5100 Touch Pad Replacement, Touch Pad: passo 5, imagem 3 %32
    • Disconnect the touchpad cable attached to the motherboard.
    • Be careful lifting the Flat Flex Cable (FFC) connector as it is quite fragile.
  6. Dell Inspiron 14 5100 Touch Pad Replacement: passo 6, imagem 1 %32 Dell Inspiron 14 5100 Touch Pad Replacement: passo 6, imagem 2 %32
    • Peel off the tapes securing the touchpad to the keyboard assembly.
  7. Dell Inspiron 14 5100 Touch Pad Replacement: passo 7, imagem 1 %32
    • Remove the four screws securing the touchpad to the keyboard assembly using the Phillips #0 screwdriver.
  8. Dell Inspiron 14 5100 Touch Pad Replacement: passo 8, imagem 1 %32 Dell Inspiron 14 5100 Touch Pad Replacement: passo 8, imagem 2 %32 Dell Inspiron 14 5100 Touch Pad Replacement: passo 8, imagem 3 %32
    • Remove the three screws securing the touchpad bracket to the keyboard assembly using the Phillips #0 screwdriver.
    • Lift the touchpad bracket.
  9. Dell Inspiron 14 5100 Touch Pad Replacement: passo 9, imagem 1 %32 Dell Inspiron 14 5100 Touch Pad Replacement: passo 9, imagem 2 %32
    • Lif tthe touchpad and replace with the new touchpad.
    • Make sure to guide the touchpad cable along with the touchpad to avoid damaging the parts.
    • Lift the touchpad at an angle from under the touchpad bracket to avoid damaging the touchpad or the touchpad bracket.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 20
Duração total: 1,040
