Ir para o conteúdo principal
Dell Inspiron 14 5100 Power Adapter Port Replacement
O que você precisa
  1. Dell Inspiron 14 5100 Power Adapter Port Replacement, Dell Inspiron 14 5100 Disassembly: passo 1, imagem 1 %32 Dell Inspiron 14 5100 Power Adapter Port Replacement, Dell Inspiron 14 5100 Disassembly: passo 1, imagem 2 %32 Dell Inspiron 14 5100 Power Adapter Port Replacement, Dell Inspiron 14 5100 Disassembly: passo 1, imagem 3 %32
    • Make sure to disconnect the power source to the device.
    • Remove nine screws securing the base cover of the laptop's keyboard assembly using the Phillips #0 screwdriver.
    • There are 2 sets of screws.
    • Remove the 3 captive screws.
    • Remove the 6M2*6 screws.
  2. Dell Inspiron 14 5100 Power Adapter Port Replacement: passo 2, imagem 1 %32 Dell Inspiron 14 5100 Power Adapter Port Replacement: passo 2, imagem 2 %32
    • Pry open the laptop to separate the base cover from the keyboard assembly.
    • You may use your fingertips or use plastic opening tools.
  3. Dell Inspiron 14 5100 Power Adapter Port Replacement, Power Adapter Port: passo 3, imagem 1 %32 Dell Inspiron 14 5100 Power Adapter Port Replacement, Power Adapter Port: passo 3, imagem 2 %32
    • Disconnect the power-adapter port cable from the motherboard.
  4. Dell Inspiron 14 5100 Power Adapter Port Replacement: passo 4, imagem 1 %32 Dell Inspiron 14 5100 Power Adapter Port Replacement: passo 4, imagem 2 %32
    • Remove the two screws securing the power adapter port to the keyboard assembly using the Phillips #0 screwdriver.
  5. Dell Inspiron 14 5100 Power Adapter Port Replacement: passo 5, imagem 1 %32
    • Remove the power adapter port and remove it from the device.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 41
Duração total: 3,119
