Introdução
Verify with the device’s troubleshooting page whether the replacement of your heat sink is required for your situation.
This guide will go through the process of replacing the heat sink for the Dell Inspiron 14 5100.
A faulty heatsink may cause the device to overheat due to the lack of heat transfer generated by the CPU to the heatsink for the fan to cool down.
If this guide is unnecessary, go to our device page to look for the correct guide for your situation.
O que você precisa
Remove nine screws securing the base cover of the laptop's keyboard assembly using the Phillips #0 screwdriver.
There are 2 sets of screws.
Remove the 3 captive screws.
Remove the 6M2*6 screws.
Unscrew the four screws securing the heat sink to the motherboard using the Phillips #0 screwdriver.
Uma outra pessoa concluiu este guia.
