Ir para o conteúdo principal
Dell Inspiron 14 5100 Heat Sink Replacement
O que você precisa
  1. Dell Inspiron 14 5100 Heat Sink Replacement, Dell Inspiron 14 5100 Disassembly: passo 1, imagem 1 %32 Dell Inspiron 14 5100 Heat Sink Replacement, Dell Inspiron 14 5100 Disassembly: passo 1, imagem 2 %32 Dell Inspiron 14 5100 Heat Sink Replacement, Dell Inspiron 14 5100 Disassembly: passo 1, imagem 3 %32
    • Make sure to disconnect the power source to the device.
    • Remove nine screws securing the base cover of the laptop's keyboard assembly using the Phillips #0 screwdriver.
    • There are 2 sets of screws.
    • Remove the 3 captive screws.
    • Remove the 6M2*6 screws.
  2. Dell Inspiron 14 5100 Heat Sink Replacement: passo 2, imagem 1 %32 Dell Inspiron 14 5100 Heat Sink Replacement: passo 2, imagem 2 %32
    • Pry open the laptop to separate the base cover from the keyboard assembly.
    • You may use your fingertips or use plastic opening tools.
  3. Dell Inspiron 14 5100 Heat Sink Replacement, Heat Sink: passo 3, imagem 1 %32
    • Unscrew the four screws securing the heat sink to the motherboard using the Phillips #0 screwdriver.
  4. Dell Inspiron 14 5100 Heat Sink Replacement: passo 4, imagem 1 %32 Dell Inspiron 14 5100 Heat Sink Replacement: passo 4, imagem 2 %32
    • Lift the heatsink and replace it with a new one.
    • When adding the new heatsink, make sure to add thermal paste to avoid overheating the CPU when in use.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 18
Duração total: 661
