Ir para o conteúdo principal
Dell Inspiron 13-7352 Memory Module (RAM) Replacement
O que você precisa
  1. Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Battery: passo 1, imagem 2 %32 Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Battery: passo 1, imagem 3 %32
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
    • Use the plastic opening tool to pry up and loosen the back panel.
    • Remove the back panel.
    Pergunte ao FixBot
    Comentar
  2. Dell Inspiron 13-7352 Memory Module (RAM) Replacement: passo 2, imagem 1 %32 Dell Inspiron 13-7352 Memory Module (RAM) Replacement: passo 2, imagem 2 %32
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery.
    • Unclip the hard drive wire from the battery.
    Pergunte ao FixBot
    Comentar
  3. Dell Inspiron 13-7352 Memory Module (RAM) Replacement: passo 3, imagem 1 %32
    • Gently remove the battery from the rest of the device.
    Pergunte ao FixBot
    Comentar
  4. Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Memory Module (RAM): passo 4, imagem 1 %32 Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Memory Module (RAM): passo 4, imagem 2 %32 Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Memory Module (RAM): passo 4, imagem 3 %32
    • Locate your memory module (RAM).
    • Release the clips from the Memory Module by gently pushing down. This should cause the Memory Module to pop up and separate from the device base.
    Pergunte ao FixBot
    Comentar
  5. Dell Inspiron 13-7352 Memory Module (RAM) Replacement: passo 5, imagem 1 %32
    • Pull the Memory Module from its slot by grasping each side with thumb and middle or index finger to pull from the rest of the device.
    Pergunte ao FixBot
    Comentar
Conclusão
4 outras pessoas executaram este guia.
4Comentários do guia
Hello is the procedure same for 7353 ? can the ram be upgraded to 16GB. it currently has 8GB
Ali M - Responder Compartilhar
Hi! Same questions as Ali M: Is the procedure same for 7353 ? can the ram be upgraded to 16GB: It currently has 8GB and I'd like to upgrade it to 16 GB.
Roberto de Souza Santos - Responder Compartilhar
Did anyone ever get an answer if it can take 16 GB of RAM?
Robert Iversen - Responder Compartilhar
A 16GB RAM would work but it should be a single sodimm module like CT204864BF160B
Hochan Son - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 43
Ao todo: 3,672
