Introdução
This is a guide for removal and replacement of the Display Assembly for the Dell Inspiron 17-7347 laptop.
O que você precisa
Flip the device over, so that the back is facing up.
Remove the ten, 7 mm, Phillips #1 screws on the back of your Dell Inspiron 13-7347.
Use the suction cup to lift off the back case.
You should be able to identify the fan.
This is the 2.5 mm JIS #00 screw.
This is the 4 mm JIS #00 screw.
Using a Phillips #0 screwdriver, loosen and remove the two 3.0 mm hard drive screws.
Lift the hard drive up and out of the device.
Using a Phillips #0 screwdriver, remove the three 3.0 mm heat sink screws.
Remove the Heat Sink.
