Ir para o conteúdo principal
Dell Inspiron 13 7378 Heat Sink Replacement
O que você precisa
  1. Dell Inspiron 13 7378 Heat Sink Replacement, Back Cover: passo 1, imagem 1 %32
    • Set the laptop with its underside facing up for improved accessibility.
  2. Dell Inspiron 13 7378 Heat Sink Replacement: passo 2, imagem 1 %32 Dell Inspiron 13 7378 Heat Sink Replacement: passo 2, imagem 2 %32
    • Using a Phillips #00 screwdriver, extract the nine 3 mm screws located on the back of the laptop.
  3. Dell Inspiron 13 7378 Heat Sink Replacement: passo 3, imagem 1 %32 Dell Inspiron 13 7378 Heat Sink Replacement: passo 3, imagem 2 %32 Dell Inspiron 13 7378 Heat Sink Replacement: passo 3, imagem 3 %32
    • Carefully pry open the back of the back of the laptop using opening picks.
    • Carefully raise and detach the back cover from the laptop.
    • Exercise caution to prevent damaging or cracking the device's back cover.
  4. Dell Inspiron 13 7378 Heat Sink Replacement, Heat Sink: passo 4, imagem 1 %32
    • Carefully remove the four screws securing the heat sink by using a Phillips screwdriver.
  5. Dell Inspiron 13 7378 Heat Sink Replacement: passo 5, imagem 1 %32 Dell Inspiron 13 7378 Heat Sink Replacement: passo 5, imagem 2 %32
    • Check to see if the fan will obstruct the removal process and if so, remove the fan first before removing the heat sink to prevent any damage.
    • In the absence of any obstacles impeding the removal process, gently lift and extract the heat sink from its position.
  6. Dell Inspiron 13 7378 Heat Sink Replacement: passo 6, imagem 1 %32
    • Before you install a new compatible cooling system, place a fresh coat of thermal paste in the center of where the previous cooling system used to be.
Conclusão
Replace the back cover to complete the process.
3 outras pessoas executaram este guia.
Javier Perez
Membro desde: 02/08/22
277 Reputação
Autoria de 2 guias
Equipe
Gateway, Team 1-3, Saknee Spring 2022 Membro de Gateway, Team 1-3, Saknee Spring 2022
GCC-SAKNEE-S22S1G3
Membros da 5
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 17
Duração total: 289
